Old 08-19-2021, 01:56 AM
groovebrother groovebrother is offline
Default pro tools 2021 : add mp3
Hi all,
i am not very familiar with that new PT version so i noticed that we could add mp3 when bouncing to disk.
Let's say i am bouncing at original sample rate (24/96) and i click add mp3.
Will pro tools apply dithering ?
Normally i am using the L2 so if i want to bounce at original sample rate i would have the following settings :
quantize : 24 bits
dither : none
shaping ultra
before if i wanted to make mp3 i would have the following L2 settings :
quantize : 16 bits
dither : Type 1
shaping ultra
but now i am wondering what to do with this new pro tools version
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 08-21-2021, 09:19 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: pro tools 2021 : add mp3
From the Reference Guide:
Bouncing to disk does not apply dither when reducing bit depth. To apply dither when bouncing to disk, you should insert a dither plug-in as the last processor in the signal path on a Master Fader assigned to the Mix Source audio output path.
It's my understanding that you don't need to add dither to an MP3.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-21-2021, 09:34 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Adding 16-bit dither to an MP3 is actually a good idea since most players truncate to sixteen bits.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 08-24-2021, 01:35 AM
thank you guys
My soundcloud page
Old 08-24-2021, 01:43 AM
JFreak's Avatar
JFreak JFreak is offline
MP3 is done after WAV bounce, so either you have or have not added dither but the process of "adding" MP3 comes after your lossless deliverable is bounced.
Janne
Old 08-24-2021, 05:24 AM
Sardi Sardi is online now
You can bounce directly to MP3.
Are you implying that PT (if you choose to bounce directly to MP3) is first bouncing to WAV, then converting the file to MP3 and automatically deleting the WAV file?
JFreak's Avatar
Yes
Janne
Old 08-24-2021, 05:27 AM
Is this documented anywhere?
Does this also apply to exporting a clip as an MP3 or just when bouncing?
Old 08-24-2021, 05:29 AM
JFreak's Avatar
That I do not know, but creating .mp3 is offliad process that haopens after bouncing lossless. It is not streaming like Sonnox ProCodec.
Janne
Pro Tools 2021.6 LDS Pro Tools 267 10-02-2021 10:59 AM
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility Spoil the Child macOS 19 04-05-2021 05:35 PM
