Old 10-17-2013, 03:26 PM
JayB JayB is offline
Default Pro Tools 10 - Xpand 2 and Boom not installed?
I'm having some trouble with the Virtual Instruments installer with Pro Tools 10. For whatever reason, after running the installer, the virtual instruments are not available in Pro Tools 10. I'm specifically looking for Xpand 2, but I know more are included.
Old 10-17-2013, 04:51 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools 10 - Xpand 2 and Boom not installed?
The virtual instruments are a separate installer rom the pro tools installer! Did you download and install the instruments installer from your Avid account?
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-17-2013, 05:15 PM
Originally Posted by crizdee View Post
Chris
Yep, I did, but for some reason they still aren't showing up.
< admin edit: New topic moved to https://duc.avid.com/showthread.php?t=417196 >
Last edited by DigiTechSupt; 09-27-2021 at 01:10 PM. Reason: New topic moved to https://duc.avid.com/showthread.php?t=417196
Old 10-19-2013, 09:37 AM
Bump
Old 09-27-2021, 01:06 PM
basslik's Avatar
basslik basslik is offline
Used to be that on your account it would list everything your entitled too. Now you only have limited access (REALLY).
Also why don't they list what you are entitled too and categorize what plugins & virtual instruments go with what version of PT.
I got PT10.3.10 installed and using for raw tracking mostly, with some limited virtual instruments for click track and don't know which virtual instruments, Structure/ Xpand/ Etc.
It would be really helpful to group PT versions with associated instruments. (PLEASE).
Can anyone direct me to the the virtual instruments & effects for PT10, thank you.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Pro Tools 10 freezing, XPand missing [installed on SSD w/ OS] avryluy Windows 2 03-01-2014 08:07 AM
xPand, Boom etc GONE in PT 10 delux3 Virtual Instruments 1 09-06-2013 03:50 AM
Upgraded to 10.3, no boom/Xpand/Etc sloanautomatic Virtual Instruments 2 05-12-2013 09:08 PM
Mini grand, Boom and xpand problems bonzerboy Pro Tools 9 3 11-26-2010 07:51 AM
MiniGrand, Boom and Xpand Libs not found innesireinar Virtual Instruments 2 12-22-2008 04:32 PM
