  #21
Old 03-22-2022, 10:46 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Alt Tab doesn't work when Pro Tools is open
Split the screen between the two?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #22
Old 03-23-2022, 04:13 AM
chrismeraz chrismeraz is offline
Your idea about the split screen is good. Unsurprisingly, the Windows "Snap Assist" commands don't work in UAD Console or in PT. So, first I have to resize the Console window and put it in it's place, then resize the Edit window, resize the Mix window, resize the Pro Tools container window and then put it in its place. Pain in the butt.
I wish I had a Mac because I just have to slide on the trackpad with three fingers left or right to switch to another virtual desktop. I tried one last week and I loved it.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
  #23
Old 03-23-2022, 10:21 AM
The Weed's Avatar
Windows 10 Virtual Desktops.
SonoBus
  #24
Old 03-24-2022, 02:41 AM
Thanks again Bruce. However, without being able to use the keyboard shortcuts, virtual desktops are actually more cumbersome than just clicking on the app icon in the task bar.
So, just to recap the shortcuts that don't work in PT on Windows:
  • Any keyboard shortcuts mapped to mouse buttons in KensingtonWorks
  • Windows Virtual Desktop or Task View shortcuts
  • Windows Task Switcher shortcuts
  • Windows Snap Assist shortcuts
  • Alt + Tab (will permanently disable Ctrl key in PT)
  • Win + Tab
  • Win + number key
  • Ctrl + Win + arrow key
  • Win + arrow key
Do you guys personally know anyone at AVID who would be willing to actually work on this? I tried making tickets about this issue for two years and I had no help. It seems important enough to me, but what do I know.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
  #25
Old 03-24-2022, 09:50 AM
SOLVED, more or less:
I found a strange little workaround. After using Alt + Tab to hop around windows, once I get back into PT I just have to hit the Alt key twice in a row. Then the Ctrl key starts working again.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
  #26
Old 06-29-2022, 10:48 AM
dfparent dfparent is offline
Don't know if folks figured this out, but on Windows 10 using Pro Tools LE (don't judge I'm on a budget) if I press Ctrl+Esc while in Pro Tools that brings up the Start menu. Then Alt+Tab works. YMMV. Just thought someone else might benefit from this tip.
  #27
Old 09-30-2022, 12:09 PM
BeatleNut BeatleNut is offline
Easiest work-around is to click mouse on taskbar (taking the focus off Pro Tools), then tab-alt will work. But the first tab is Pro Tools, so get in the habit of tabbing twice for the next screen.
This has annoyed me for years. Why won't Avid create a fix? Maybe they did with their subscription, but so far I've resisted that offer. PT11 is fine.
Spacebar doesn't work as start/stop with plugin open Downtown_BE macOS 6 11-05-2014 06:19 PM
Dbl-click to open MIDI Editor doesn't work mkoplin macOS 1 03-19-2012 06:41 PM
pro tools 8 bounces but doesn't open! shayla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-24-2010 10:05 AM
PT LE 8 BUG: Shortkey doesn't work when a plugin window is open ugosound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2009 11:09 AM
Pro Tools doesn't open MSCHAAF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-15-2008 04:54 PM
