Old 05-09-2023, 02:21 AM
idris idris is offline
Default Mono to 5.1 upmix
I've been asked by a client if I could do some mono to 5.1 upmixes.
I've read pleanty on Halo, Penteo and Waves, but as far as I can see, those all need to start from stereo.
Any experience of the less well known plugins that claim to handle mono?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 05-09-2023, 09:29 AM
smurfyou smurfyou is offline
Default Re: Mono to 5.1 upmix
I don't know what your client expects.... but this is usually wishful thinking with a single mono mix. Usually requires some sort of remix and maybe additional sound design/edit.
But there is a Schoeps Mono Upmix plugin that goes to L-C-R. I've use that to spread old mono sound like b-roll and nat sound.
~Will
Old 05-09-2023, 02:49 PM
quadraphonics quadraphonics is offline
I used to do this when I worked for a company called Chace Productions. It was a combination of phase manipulation and editorial. Took quite a bit of work for limited result.
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 05-15-2023, 11:21 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I made a restoration for older films (in mono).
There are some opinions today that there is "a thin, center only sound" when it comes only from the center.
It might be true in large cinemas halls but yet you should keep original feel and artistic intentions of the mix. So there is no really easy solution for that.
However what I did and IMHO it didn't harm the film, I sent some audio to L and R by divergence control set on 90% in C. So it became LCR (still remaining mono). You can manually send music or some low end effects to the Lfe.
I also made a stereo track containing dual mono and inserted on it Halo st to 5.0. It did some reverb extraction and I sent it exclusively to LsRs and terminated the L,C,R it produced.
At the end in my 5.1 bus I diverged a bit front and rears signal with the Spanner (5-7%).
So the result was a 5.1 which sounded very close to original but with some sense of space at the same time.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 05-19-2023, 11:24 PM
aholicsound aholicsound is offline
You can use a stereoizer ahead of penteo and it works fairly well. I think you should be honest with your client on the limitations and that it'll basically be an LCR mix with some LsRs scattered in there...but it does work.
I used the bx_stereomaker to good effect for this exact issue.
Sent from my Pixel 5 using Tapatalk
leaving the world a better sounding place
Old 08-03-2023, 03:56 PM
FunkzzaJ FunkzzaJ is offline
I use DearVR Music. It does just that. Mono input, and outputs binarial, stereo, and FOA. It's bigger brother DearVR Pro adds 5.1 and upwards. Check it up. Maybe it is 4 U.
/T
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
HTML code is On
Upmix test jbelliston Post - Surround - Video 11 08-10-2014 11:53 PM
Penteo 4 Pro - 5.1 upmix MIKEROPHONICS Post - Surround - Video 79 05-21-2014 09:30 AM
Dts upmix - anyway to AS render a 5.1 file with.... Brandonx1 Post - Surround - Video 3 10-25-2012 11:39 AM
Stereo to 5.1 upmix on a budget idris Post - Surround - Video 9 10-05-2012 06:13 PM
does cycling 74 upmix work in LE john1192 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2007 12:59 AM
