Re: Emagic Logic vs ProTools & Logic
I used Logic with OMS and with Emagic hardware (MT4). My opinion it is better with out OMS. Some people like using it with OMS and have no problems. I tried had a few and bought the MT4. I understand the problems were solved with new 5.1 drivers. I don't know much about the latency issue, did not use OMS long enought to see if there was a problem or not. I would think at this point it will be a matter of what your needs are. If you use OMS, you'll save yourself the money on buying a midi interface becasue you can use the 001 midi ports. If you need more than one midi i/o then just buy yourself the Emagic interface and skip OMS.
Just my opinion Toecat |
no but with the appropriate hardware you can support 96k i use digi as a basic i/o.
what i was getting at is the options in logic that dont and most likley never will exsist in pt le. |
i normally dont run enough midi to run into latency problems however what i do like is the lack of latency for audio ! otherwise i feel that the digi 001 is a cost effective solution to a sound card for logic not the BEST and by no means the WORST.
best of luck . |
Need help with Older Protools TDM mix plus 5.1.3 and Logic Platinum 4.( emagic ) | ptgdog | General Discussion | 1 | 01-22-2011 06:34 PM |
More Emagic Logic complaints | John Wilkinson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-16-2004 07:02 AM |
Emagic Logic Pro at NAMM | Tone | Pro Tools TDM Systems (Mac) | 21 | 01-16-2004 09:57 AM |
pro tool vs emagic logic | flytrap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-19-2001 04:17 AM |
Emagic Logic...anyone using? | Tigerbaby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-19-2000 10:57 AM |
