Re: Pro Tools 11 automatically changes sample rate when opening
On PC, try setting your on-board soundcard as the default for Windows sounds/audio and leave the other interface strictly for Pro Tools. You may have to change the sample rate in your interface's software before opening Pro Tools.
Cheers,
It appears to be a new problem with PT11 on Windows.
When I want to work on sessions at different sample rates, my only solution is to open PT11, then connect a second soundcard so Windows can use that as its new default soundcard, and only then does PT11 appear free to use my main soundcard at whatever sample rate I want. I've only recently upgraded from PT8 and it never happened on that system. It's odd to have to do this workaround so I hope Avid can solve the problem soon. |
Does your computer not have an onboard sound card - and if not, why not just install a cheap one for Windows audio?
Cheers,
I would prefer Avid to fix the problem rather than buying a sound card I won't use.
Do you use Mac or Win? It's not the issue of pro tools. I had the same problem before.
#16
Same problem even if you hold down the N key and manually select the MOTU as the playback device?
After a bout of these issues with Focusrite I switched to Mac to adopts the issues, it had been smooth sailing ever since (kow)
#17
You will use the sound card - for all other audio except Pro Tools. It's either that or wait a long time - or possibly forever - for Avid to allow Pro Tools to share an interface.
Cheers,
Determine Sample rate without opening Protools | JCBigler | Pro Tools 11 | 6 | 01-19-2014 07:22 AM |
Pro tools 11 problems opening PT 10 sessions. Sample rate error 44.1 and 48 KHz | pjthorpe | Pro Tools 11 | 17 | 11-14-2013 08:10 AM |
Problem Opening Sessions in Pro Tools 9: Sample Rate Sync Issue. | anthonymunoz | macOS | 0 | 10-23-2011 08:49 PM |
Finding sample rate in PT session without opening..Is is possible? | jarrydee | Pro Tools 9 | 9 | 01-15-2011 04:40 AM |
CoreAudio-Sample rate automatically switch to 44.1 | thepantsdancer | Pro Tools TDM Systems (Mac) | 0 | 12-23-2005 08:23 AM |
