Shortcut to render 1 kHz tone in selection (not working)
I originally posted this in the wrong section. Posting here instead, as it's a PT10 issue.
For some reason the Shift+Win+Alt+3 (Control+Option+Shift+3 on Mac) command is not working in Pro Tools 10HD. It's working in 11HD, though. Has anyone else experienced this? |
Re: Shortcut to render 1 kHz tone in selection (not working)
Does the audiosuite signal generator work for you OK if you do this manually?
It does. I'd still like the shortcut to work, though.
Yeah, it's strange. I select one frame, use the shortcut. Works fine in PT11. It used to work in PT10 as well, now it doesn't. I've tried a fresh install, but no dice.
here's too in pt 12.5, not work.
Corrado Magalotti Tam Tam Recording studio |
Unable to adjust my audio suite plugins.
I am having an issue with several of my audio suite plugins where they don't allow me to adjust anything. For example in Varify I can't click "speed up". "Slow down" is default so it work just fine. Another example is in the 7 band eq I can't adjust the eq at all. It's like they are frozen. Any help would be great.
Re: Unable to adjust my audio suite plugins.
"Recording." Please start a new thread, and provide SPECIFIC system details.
Edit Selection Follows Clip List Selection not working | Sjoberg | Pro Tools 10 | 3 | 12-04-2020 12:38 PM |
Audiosuite Render key shortcut | :Rob: | Pro Tools 10 | 18 | 07-24-2017 01:22 PM |
Consolidate selection shortcut not working? | larry saldano | Pro Tools TDM Systems (Mac) | 5 | 05-18-2005 03:20 PM |
selection shortcut? | rogga_bogga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-07-2005 02:25 PM |
Shortcut for Zoom to Selection? | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-06-2003 01:57 PM |
