Crash when Closing Pro Tools 8.0.1 (every time)
I was wondering if anyone else has issues with pro tools 8.0.1 Freezing the mac when they actually quit pro tools for the day or when quitting pt to eject a hard drive etc.
When I quit pro tools it basically freezes up my mac and I have to restart. This happens literally every single time. I had 8.0 running very smooth and then with 8.0.1 this started. Any Ideas? I have read the other thread where people state that PT crashes going from song to song. I do not have that problem at all. I sometimes have that Not enough DSP from opening the same song but that is another subject. Anyway I am more curious about the first issue. If anyone else has this issue or a fix let me know. I hate having to restart the Mac every time I want to eject a drive or just simply quit Pro tools. Thanx and sorry if this has been covered I just simply couldn't find it
www.nightskystudios.org |
Re: Crash when Closing Pro Tools 8.0.1 (every time)
There's no need to quit PT to eject a CD or unmount a Drive!! just go into the workspace browser and "right click" on the CD or drive in the list and select unmount. When PT quits do you get a crash log? this will usually indicate the possible cause. Common cause is an out of date or incompatible plugin, have you checked all plugs are up to date and compatible? Trashed prefs? and delete data base files? this might fix it! try using this app..... http://duc.digidesign.com/showthread.php?t=190122 Chris
Hey man - I went through the exact same thing and it turned out to be a plug in (s). Start by removing all VI's, make sure you are up to date on the rest and go from there. I'm on 8.01 and rock solid since going through this process.
Good luck. |
Thanx for the info guys, Yeah I have tried the trash pref things as well as data base files.
Looks like I just need to go through the plugs, which sucks. DT which plug was it for you that was causing the issues. Like I said everything was great on 8.0 and the 8.0.1 update started the crash. I checked all compatability when moving to 8 and i was up to date, just the 8.0.1 once again caused this. Ok thanx again for all the helpful info.
I had this EXACT same problem.
My Solution 1) CLEAN De-install (Remove everything) 2) Fresh Install 8.0 ( Don't do any CS update) 3) Install 8.0.1 update 3) Find the offending plug-ins not 8.0.1 compatible ( This is the hardest part ) I have lots of plug-ins and am using an expanded system in A Magma PE6R4 8.0.1 has been super stable for me. I get maybe 3-4 crashes per week mostly due to me going too fast on the Icon and Keyboard at the same time or due to plug-in caching and trying to open several sessions in a row too fast or with plug-in cache turned on |
In the end for me it was the Lexicon PCM 96 plugs that weren't up to date.
I also removed Mach Five 2 and Amp Farm. Elastik/Stylus/Omnisphere/Steinway all seem to be fine. The system went from a nightmare to rock solid just by doing this. Also, this week I upgraded my G5 to an 8 core Intel/Magma and several other minor issues seem to have disappeared, the biggest of which being the horizontal scrolling problem. Good luck. dt |
dt-
I'd bet that the video RAM on the MacPro is better then the old G5 - Leopard seems to do everything smoother on the MacPro. We still have the scrolling problems in 8.0.1 - not a video card issue - just a code thing with Cocoa (so DTS claims). If we're talking about the same scrolling issue.
... but does it help the chorus? |
Thanx for all the help guys. I am back in the studio tomorrow and I will do all the things you guys mentioned. I know for a fact I still have an amp farm in the plug ins folder for sure. I will try that first. Then on to the million other ones haha.
Thanx again
Looks like I found the 8.0.1 Crash Support Group. I'm glad to know it exists.
I started getting these crashes recently. Not EVERY session crashes, but about half do. It seems like this all started when I upgraded PCM96 and Duende software, which I did at about the same time. Omnisphere was also updated recently. I'm going to start removing plugins to see if I can find a culprit. I HATE having to do this. It's a loooong and boring process, unless you find it right away, which rarely happens. If anyone finds further specific causes for this crash, please post with the solution. |
Crash Upon Closing Session | MIKEROPHONICS | Post - Surround - Video | 19 | 11-16-2013 12:30 PM |
MPEG-4 (perian) movie causes crash upon closing the session | Sunzate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-01-2009 10:16 PM |
ProTools Crash when closing | Marcus S. | Pro Tools M-Powered (Win) | 0 | 11-27-2006 07:36 PM |
Why does Rewire crash ProTools upon closing? | PastaViking II | Pro Tools TDM Systems (Mac) | 17 | 07-07-2006 06:10 PM |
Pro Tools v5.1.3 Crash When Closing Session | Chief Technician | Pro Tools TDM Systems (Mac) | 22 | 09-21-2002 03:17 PM |
