stream deck, macros, windows & Pro Tools not working
a couple of days ago I bought a Stream Deck after reading so many raging reviews... only to realize it does not work propperly with Pro Tools under windows.
Neither do other macro/hotkeys software for that matter. Is windows Pro Tools (2020) cripled? anyone has experience regarding this?
PC i79700K 4.8Ghz 32Gb ram Nvidia1050 Win 10 64 SSL MX4 |
Re: stream deck, macros, windows & Pro Tools not working
Any update with this?..
I was considering getting one, but seems iffy still?.. |
Ah, google brought me here - I have been battling with AHK and my Logitech mouse and Pro Tools hijacking the Win/Start and Alt keys completely from the OS - I was under the assumption that Streamdeck had done some magic to circumvent this but apparently not?
(I.e. Ctrl and Shift are the only modifiers that work normally under PT, as well as Alt-Tab which is also a way to "give" the Win key back to the OS) This PT Win key implementation definitely should have some more elegant solution, and if it's not possible at least we should be able to customize our own key sets.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3 Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1 HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES. |
For your mouse, look at X-Mouse Button Control.
I would pose the question to Stream Deck. I remember early on that they were not so Windows-friendly and programming had to be done with a Mac(but then it WOULD work on a Windows system). Not sure if that changed
Have a Similar problem with Streamdeck and Protools. Sure, I can press the Windows key + xxx but if I assign it in Streamdeck it doesn't respond. I tried in Loupdeck. A similar thing it Doesn't Respond. I even tried it with the Touch Portal Low-Level key... still it doesn't respond.
So, I guess it's not a problem with other devices... it is in ProTools integration... Have anyone found a solution for this? |
Pro Tools tabbed windows in MacOs - Windows configuration not working | hugocentrique | macOS | 3 | 11-06-2023 05:26 AM |
Artist Transport Macros not working anymore | edwinstar | Artist Series | 30 | 04-06-2017 10:27 AM |
This is a great ipad app for making macros and controlling PT for OSX and Windows | Neil H | General Discussion | 0 | 12-20-2015 06:55 AM |
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... | Jon Vandenbor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-01-2015 02:10 PM |
windows start key artist macros | eddie lamb | Artist Series | 2 | 10-28-2013 11:42 AM |
