003 Rack+ ASIO driver and first-time install of PTLE 8 not working
I'm on a Dell running Windows Vista Business SP2, and I just installed PTLE 8 and upgrade to 8.0.3. Prior to this no version of Pro Tools was on the system. But ever since I installed, I'm having problems getting PTLE to work, and Digi ASIO driver use for Soundforge is also not working.
With PTLE, at first launch, I got the hardware not found error. After upgrading to 8.0.3, every other time since then it freezes up at "Creating DAE Objects", except once it actually finished loading, but then when I tried creating a session, it froze up. Also, any time it freezes up I can't kill the ProTools.exe task when it freezes, and it won't stop running until I power off the 003 Rack+. Now in SoundForge 9, when I go to audio settings I can select the Digidesign ASIO driver and click ok. Then when I try to play an audio file, it simply freezes and the play cursor doesn't even move, and the program stops responding. And as with PTLE, I can't quit the program or kill the task until I power off the 003. Can someone PLEASE help me out here? I've never been so frustrated by a product not working right out of the box like this. It's making me want to return it all and use something else. Thank you! |
Re: 003 Rack+ ASIO driver and first-time install of PTLE 8 not working
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Ok I ran through everything on the troubleshooting post, including un/reinstalling Pro Tools LE, and installing with 'run as administrator'.
Here are the specs from SANDRA Computer Overview: SiSoftware Sandra Computer Model : Dell Precision WorkStation T3400 Domain : 2KGAMES Host Name : novw-mmaksim User : Michael Maksim Processor Model : Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Dell 0TP412 BIOS : Dell A09 06/04/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB ECC DIMM DDR2 DDR3 Chipset Model : Dell X38 Processor to I/O Controller Front Side Bus Speed : 4x 332MHz (1.33GHz) Total Memory : 8GB ECC DIMM DDR2 DDR3 Memory Bus Speed : 2x 398MHz (796MHz) Memory Module(s) Memory Module : Nanya NT2GT72U8PD0BY-AD 2GB ECC DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Nanya NT2GT72U8PD0BY-AD 2GB ECC DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Nanya NT2GT72U8PD0BY-AD 2GB ECC DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Nanya NT2GT72U8PD0BY-AD 2GB ECC DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 8800 GTX (128 SM4.0 1.25GHz, 768MB DDR3 2x900MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8800 GTX (128 SM4.0 1.25GHz, 768MB DDR3 2x900MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8800 GTX (128SP 16C 1.35GHz, 768MB 2x900MHz) Adapter : NVIDIA GeForce 8800 GTX (128SP 16C 1.35GHz, 768MB 2x900MHz) Adapter : NVIDIA GeForce 8800 GTX (128SP 1.25GHz, 739.2MB 2x900MHz) Storage Devices WDC WD2500AAJS-75M0A0 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 233GB (C:) Seagate ST3500320NS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) : 466GB (D:) Optiarc DVD+-RW AD-7200S (ATAPI, DVD+-RW, CD-RW, 960kB Cache) : 8GB (E:) Logical Storage Devices OS (C:) : 233GB (NTFS) @ WDC WD2500AAJS-75M0A0 (250GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Local Disk (D:) : 466GB (NTFS) @ Seagate ST3500320NS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) Pro Tools LE (E:) : 8GB (CDFS) @ Optiarc DVD+-RW AD-7200S (ATAPI, DVD+-RW, CD-RW, 960kB Cache) Peripherals LPC Hub Controller 1 : Intel (ICH9) LPC Interface Controller LPC Legacy Controller 1 : SMSC SCH5514D-NS Audio Device : Dell (ICH9) HD Audio Controller Audio Codec : Analog Devices AD1984HD sound chip Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Dell (ICH9) 6 port SATA AHCI Controller USB Controller 1 : Dell (ICH9) USB Universal Host Controller USB Controller 2 : Dell (ICH9) USB Universal Host Controller USB Controller 3 : Dell (ICH9) USB Universal Host Controller USB Controller 4 : Dell (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Dell (ICH9) USB Universal Host Controller USB Controller 6 : Dell (ICH9) USB Universal Host Controller USB Controller 7 : Dell (ICH9) USB Universal Host Controller USB Controller 8 : Dell (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Adaptec TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : HP LaserJet 4250 PCL 6 (1200x1200, Colour) Network Services Network Adapter : Broadcom NetXtreme Gigabit Ethernet (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Business 6.00.6002 (Service Pack 2) Platform Compliance : x64 Windows Experience Index Current System : 1.0 Please someone help me get this working. If I can't get it working by end of the week I'll have to return everything, get a different FireWire audio I/O device, and use Nuendo instead. Thanks! |
I wouldn't waste time. Return the DIGI hardware and get something that works out of the box. Unless you want to run Windows XP SP3 partition, you won't get a stable set up.
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts." -Albert Einstein Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub |
Well I know it will be unstable. It is Pro Tools *LE* after all, and I'm running it on a PC. But I *should* at least be able to get it to f@#*ing launch.
Ok so I *WAS* able to get it to launch... once. I swapped out my firewire card and cable for a shorter one. Here are the specs for the new card: FireWire/1394 Controller 1 : Onnto uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr However, I *STILL* have a problem. Although I was able to launch the program and create a session (once), as soon as I created a track and hit play I got the "audio clock" error, resulting in flashing play and stop buttons. I hit stop to clear the flashing buttons and tried playing again, but the same problem occurs repeatedly. And after quitting and restarting, now the launch hangs at "Setting up Peripherals, Initializing Controllers". You know what? F|_|C|< it. If I can't get this godforsaken crap working today I'm returning it and getting something that works on PC right out of the box, like Nuendo and some other FireWire I/O. I'm tired of wasting days of my time trying to make a [bleep][bleep][bleep][bleep]ty product work. Come on, Dodgydesign/Avid. Why can't you make stuff that works and doesn't cost thousands of dollars!? You know, like all of your competitors do? Losers. |
Not necessarily true - I actually (finally) have a very stable ProTools LE setup in Windows 7 64-bit along with many other users.
OP, get a FF800 and you'll never look back. I've heard nothing but great things about them, great pres, conversion, low-latency, rock solid drivers, etc... I was actually going to go down that route, but opted for a lunch box of pres, a Lynx Aurora + AES16 (eventually). Good luck mate.
BTW, just search my name and you'll see how many and what kinds of problems I've had with Pro Tools in just the past 2-3 years. :P
Not to try to diminish the horror stories, they are real. I do however have PT8.0.3/0.4 running well on a custom built computer. A T.I. firewire controller and driver and ATI video cards were a must for me. Fast RAM and drives were also essential. Doing all of the recommended W7 optimizations and following the installation instructions lead to reasonable success. It took me only two weeks to get this done.
ASIO Driver Not Working! | tenkproductions | Pro Tools TDM Systems (Win) | 10 | 02-04-2017 11:34 PM |
ASIO driver won't install | seagull | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-25-2009 11:57 AM |
ASIO 7.0 driver on ptle 6.9? | maroc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-01-2006 05:27 AM |
Is there a new ASIO driver with PTLE 7? | James A. Abdo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-17-2005 10:37 PM |
ASIO Driver Install Problem | splattstudio | Pro Tools TDM Systems (Win) | 9 | 11-05-2003 12:05 AM |
