tascam m3500 analog board
Is ther anyone familiar with this board considering purchasing for 1000 w/meter stand and power supply.looking to run mx2424 and 8 out of digi 001.rosetta 96 converters grace 201 pre amps and digimax lt for drums. How does this compare to the mackie 32x8 as faras the eqs and mix bus? thanks alan
Re: tascam m3500 analog board
Hey Alan,
It's been a while since I've used a 3500 but I remember loving the sound. I've used a Mackie 32X8 for the last 6 or so years but I can't remember ever saying I love what I can get out of it. If your gonna do most eq'ing in PTs, as long as the board gives you a clean (uncoloured) signal, either one will probably be good. If memory serves, the 3500 has mini faders for the monitor mix, is that right? If so, I'd lean towards that. I think the hook up choices are only subtley different. Your biggest problem would be if you use the board to mix, you won't be able to recall the eq settings. You'll have alot of hook up choices even when you DO decide!! Good luck! Ter |
I like the sound of mine. I can take 16 discrete outs from pro tools and sum using the board.
It is an inline console and the 32 small faders can be flipped with the 32 big faders. Keep in mind this board is primarily unbalanced. All of the direct outs, line inputs, and tape inputs are unbalanced. A balancing kit was available for each group of 8 channels but hard to find today. I have troubles with noise that I have not been able to resolve, although the power to my room is less than ideal.
Custom Built Intel Core2 Quad Q9550 Yorkfield 2.83GHz ASUS P5Q Deluxe LGA 775 Intel P45 Zalman CNPS9500 cooling Fan ASUS EAH3450 512MB Radeon 64 bit video SIIG 1394 PCI firewire Corsair 650 Watt power supply Corsair 4GB DDR2 1066 ram 2X Western Digital Caviar 640GB SATA 3.0Gb/s Lite-On 20x DVD-r Dual 22" Hannspree LCD Control 24/Digi 003R/PT10/RME ADI-8/Waves SSL/Waves Platinum/URS CSP/IK Total Studio 2 bundle/Massey/Strike/MPTK 1 |
Can the Tascam 2488 be MIDIed and used as a Control BOard | jronkindy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-02-2010 09:31 AM |
tascam m3500 32x8 or dm24? | aeugene | Pro Tools TDM Systems (Mac) | 1 | 02-17-2004 01:59 PM |
tascam m3500 32x8 or dm24 | aeugene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2004 10:52 AM |
dip switches on tascam sy-88 board for mtc transmission | jarrett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-03-2002 04:54 PM |
Tascam M3500 | Obscene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-01-2002 08:12 AM |
