Old 10-27-2005, 01:47 AM
Armando Armando is offline
Default Ethernet wiring(behind the wall) info needed
Hello,
I'm in the process of having all my control room audio and data wiring installed behind the walls prior to drywall installation. I'm doing this myself. I've run multiple Mogami 8 channel snake runs for audio transmission between 192 I/Os and the Control 24 and CAT5E for communication between the Mac and the Control 24. These will all be terminated by female DB25 and RJ45 jacks on custom wall panels on their corresponding walls.
Are there certain wiring guidelines I need to follow when terminating both the female DB25 and RJ45 jacks?? I'll use short corresponding male terminated snake and CAT 5 cables from wall plate jacks to the equipment(Mac, 192 1/0s and Control 24).
Thanks in advance.
I'm also posting this in the Mac section of the DUC.
Armando
Old 10-29-2005, 06:40 AM
Riad Riad is offline
Default Re: Ethernet wiring(behind the wall) info needed
Sounds like you will be fine. You should run the Ethernet cables the same as if you were wiring your office.
Rob
www.carvelstudios.com
Old 10-30-2005, 01:42 AM
bb_aus bb_aus is offline
you are not ment to wire communication cabes without a licence, however if you have the right tools its not hard to do. use brand name connectors and follow the color coding. to keep away from any power cables, if you must cross power cables make sure they cross at 90degrees
Wiring TRS Wall Plates for Headphone Feeds KineticSound General Discussion 2 06-17-2013 09:24 AM
Digidesign Ethernet Driver Disk Needed.. C-DreamZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-19-2012 09:56 PM
003 Rack info needed mcgibbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-20-2009 06:11 AM
Ethernet and audio wiring(behind the wall) info Armando Pro Tools TDM Systems (Mac) 0 10-27-2005 01:50 AM
Drum info needed jvo11 Pro Tools TDM Systems (Win) 1 09-09-2005 08:26 AM
