using control 24 mic pre\'s with 002R
i just sold my G5 with mbox because im going to be working on building my own full studio soon.
i wanted to get the digi 002rack with the control 24, but i was wondering if i could use all 16 mic pres on the control 24? if not, how would i be able to utilize the most mic pres possible. could i just plug the control 24 into my computer via ethernet and have pro tools just recognize all the pres? i dont have enough money for an HD system, so i have to stick to LE for the time being. i dont want to make the mistake of buying the wrong equipment. thanks! |
Re: using control 24 mic pre\'s with 002R
Do a search. I have ordered my Control 24 and am waiting to receive it.
Basically the ethernet transmits control language back and forth from protools, that's it. The preamp section is standalone and does not transmit through ethernet, but through two db-25 connectors on the back, almost like direct outs on an analog console. Mic-pre to output with a gain control thrown in. So to answer your question, the first 8 channels from the C24 would go into the 8 analog in's on the 002R, and then you could use an 8 channel lightpipe converter box for the other 8 channels, total of 16 in's. Or..you could use the 002r's built in preamps (4) and 14 of the control 24 preamps to the 002R (4 analog, 8 optical, and 2 spdif), with a spdif 2 channel converter box of course.
Custom Built Intel Core2 Quad Q9550 Yorkfield 2.83GHz ASUS P5Q Deluxe LGA 775 Intel P45 Zalman CNPS9500 cooling Fan ASUS EAH3450 512MB Radeon 64 bit video SIIG 1394 PCI firewire Corsair 650 Watt power supply Corsair 4GB DDR2 1066 ram 2X Western Digital Caviar 640GB SATA 3.0Gb/s Lite-On 20x DVD-r Dual 22" Hannspree LCD Control 24/Digi 003R/PT10/RME ADI-8/Waves SSL/Waves Platinum/URS CSP/IK Total Studio 2 bundle/Massey/Strike/MPTK 1 |
I have the same setup as you it seems.
I route C24 mic pre's 1-8 into the line inputs of the 002R. I then route C24 mic pre's 9-16 into a Focusrite Octopre's line inputs and then come out of the ADAT port into the lightpipe input on the 002R. This gives you 16 channels of mic pre's from the C24 and you can record them all at the same time. Basically you need a line level to ADAT converter. I happened to have an Octopre but you can use anything from a fostex vc8 upwards. Cheers Lizardpoint |
Question: Can you bypass the 002R pre's? | MeatballLE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-08-2009 03:05 PM |
How to Over-ride 002R Pre's? | Rick Akoni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2006 10:16 PM |
002r pre's | Javier Santiago | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-10-2006 06:08 AM |
More Pre's and 002R | SteelCannons | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-18-2006 07:50 PM |
Using 002R Mic Pre's with an outboard compressor.. | xeetstreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-27-2005 12:36 PM |
