Old 12-28-2015, 01:04 AM
Rockman413 Rockman413 is offline
Default What's the difference between these 2 ways of bouncing? [solved]
1. Open a new 48khz project, drag n drop a 441khz file into it, it sounds no problem (should it sounds pitch incorrect? It sounds no problem possibly it's because my PT is slaved to another clock source, but that source is invalid) Then I load some plug ins and bounce it into 48khz
2. change source into Internal,open a new 441khz project, import a 441khz file into it , it sounds more or less the same, Then I load same plug ins and bounce it into 48khz
Which way the bounced file should sound better?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 12-28-2015, 07:59 AM
KMcK KMcK is offline
Default Re: What's the difference between these 2 ways of bouncing?
Doesn't matter, you're basically doing the same thing in both scenarios, just changing when the sample-rate conversion happens.
http://www.imdb.com/name/nm2384808/
Audio not bouncing with Quicktime video [SOLVED] Jazzmaster Pro Tools 11 6 12-13-2016 08:42 AM
Difference in Bouncing Stereo to Mono and Panning? JLEpperson Pro Tools 10 1 07-10-2012 02:23 PM
SOLVED>>Need HELP, SUPER ASAP.< audioindo Pro Tools TDM Systems (Mac) 18 04-21-2007 05:43 AM
Two ways of BTD... OgnKog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2002 09:13 AM
101 ways to ask the same question PT & OSX DesertDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-07-2002 07:08 PM
