Old 02-07-2012, 09:08 PM
alithomas66 alithomas66 is offline
Default Bounced tracks are at a different speed!
I bet this is posted somewhere already, HOWEVER, I'm short on time and I apologize for any redundancies:
My sessions in PT 9 are at a different bpm than after I bounce them. The change in tempo is pretty drastic and obvious.
Does this have to do with the Word Clock too? How can I fix my problem? If someone knows the answer, please give me a shout! Thanks a lot :)
Old 02-07-2012, 09:22 PM
RegenerationMix RegenerationMix is offline
Default Re: Bounced tracks are at a different speed!
are you changing the sample rate?
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 02-07-2012, 11:41 PM
Perhaps... haha this could by would, yeah. Okay dumb question: I know it varies depending on the project, but what should the sample rate be at normally? 44 khz? thanks
the buffer size has nothing to do with my problem, right? I changed it once to get rid of unwanted pops and clicks, but that's probably an entirely different subject.
Old 02-08-2012, 06:46 AM
Describe your hardware setup in great detail. It sounds like a clocking issue to me as well. If you bounce at the same sample rate as the session, then speed and pitch should be the same. But an external clock that is set incorrectly can override what you "think" the session is done at.
Old 02-08-2012, 11:45 AM
buffer has nothing to do with the change in pitch/ speed when bouncing. But sample rates being different will change the pitch /speed. most people end up at 48K or 44.1. You probably have different sample rates going on. All must match.
Personally i end up at 44.1 which will play on a CD. Once CDs are extinct i will probably move to 48K though the sound difference i cant hear. Or when 48K becomes the standard.
Its more important to have a good bit rate. 24 bit is much better than 16bit or 8 bit.
I record at 24 bit 44.1K. I could record at 24 bit 48K. Since all of my stuff ends up as an mp3 on the internet or on a youtube video, i dont really need 48k.
my two cents.
Chris
Old 02-08-2012, 04:26 PM
I'm running on an 003.
and everything you guys are saying makes a ton of sense. I'm gonna be in the studio tonight and I'll check what's going on in the sample rate department. See if everything lines up. Settings > Hardware > sample rate. Anywhere else I should look?
When I'm bouncing, I should check the sample rate in there too, right? Sorry and thanks again
[IMG] code is Off
Bounced tracks playback incrorrectly.... dazed1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-19-2011 06:08 AM
Bounced Tracks But No sound steverido 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-30-2010 04:32 PM
Getting cd quality sound on bounced tracks? nicball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 02-24-2008 03:04 PM
Mixed and bounced to disc. plays back half speed. mwb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-01-2004 05:55 PM
missing tracks in my bounced mix files! pattino Pro Tools TDM Systems (Mac) 0 08-31-2002 12:13 AM
