SYNC I/O SMPTE and PT9 help
Friends I am having a problem with my Sync I/O and pt 9. I am trying to generate SMPTE so I can sync up my PT system to Digital Performer. I have not use Sync for a while so I think I might be missing a step. I have a Big Ben Master Clock in my set up, but for Sync to be used Apogee recommends letting Sync be the boss and then Big Ben can distribute the word clock to my other units. So, I hook up Sync to PT and use the BNC connector to connect to my Big Ben. Ben then distributes the Clock to my PT 192. In PT software I go to "session" and make sure I am synced and Locked. GREAT ... everything looks good. I can even control the Sync unit from PT. Now.... PT says go to Peripherals and click on enable Sync Peripheral... O.K ..Then Session for the rate.. Clock Ref is Internal. Now it says to click on the online button and Play... I don't think I am generating... The LTC out into DP does not show anything.... Does the front on the SYNC unit run the numbers? If I go to "sessions" should I see a running SMPTE? I don't!! I can't confirm that I am generating SMPTE.. I'm doing something wrong.... This should be simple so I know I missing something.. Any help..
Thanks Mike |
Re: SYNC I/O SMPTE and PT9 help
You need to enable "generate mode"
Also session is " online " This will generate TC when you hit play Look on front of sync IO there is a GEN mode LED Is it on ? You have a serial cable between sync io and core card? Are you generating LTC or Serial TC?
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Many Thanks to the dude,
I was using the "online" button in PT ...wrong...... I found the sync buttons that tell SYNC to generate LTC AND MTC Thanks for the reply. I think i'm good... my stupid mistake... thanks for the help Mike |
Can Mbox sync to midi timecode or smpte sync? | greeneye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2004 08:47 AM |
DVD/SMPTE sync | Engramic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-23-2003 05:22 PM |
Can this system sync to SMPTE? | Dave Lang | Digidesign Hardware & Software | 1 | 04-09-2002 10:48 AM |
SMPTE/MTC sync with 001 | Choro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-18-2001 08:33 PM |
Can't Sync to SMPTE w/ MTP AV & PT 5.1 | monkey tools | Pro Tools TDM Systems (Mac) | 5 | 04-12-2001 05:05 PM |
