![]() Quote:
Well said! Guys I think I found the main problem. I just changed all the buffer settings in the Spitfire software, there are many buffer-related parameters, like streaming buffer, pitched-voices buffer etc... Basically you can balance the load between Ram and Drives, in case you have very slow drives. (honestly I think it's a pretty rare situation among people that are used to work with big sample libraries.) Anyway, with all the buffer parameters ij the middle way between Max and Min, the amount of Ram that each plugin instance needs moves from 14-15 Gb to 700-800 Mb. ![]() Funny to say, it was taking 30gb of Ram for just two plugins with the Ssd Drive almost sleeping at 1%. Like moving a Tesla using two draft horses. With other Virtual Instruments, usually the default settings are ok for most of the situations, I don't know why on these brand new GUI Spitfire Instruments I had these crazy settings as if I had my library on a floppy disk. Anyway I'm going to add 48gb anyway cause I found 6 OWC modules for 200€/$, it'll leave me more gap in case of big crazy sessions. And also, after some tests with similar processes in the backgrouns, looks like the Mac Pro wants more Ram than a Macbook M1.
Mac Pro 2019 - Monterey - Macbook Air M1 - Apollo 8p (x2) - Apollo Twin X - Ferrofish 16Mx - Avid S1 Multi-unit |
I have also found this, but Darryl has good points which suggest more testing.
I just installed 6x8gb Owc Ram Modules in the Mac Pro 2019 and I found out this:
I had 6 Apple 8gb original modules installed in slot 1-3-5-7-9-11 so, based on the knowledge that I had about the Hexa mode and how they share the channels I've left the original modules in their position and I just add the Owc modules in the free slots, 2-4-6-8-10-12. When I turned on the Mac I had the orange light telling me there was a problem with Ram. So I checked again every module and reset. Same problem again. Then I put all the modules in pairs so, Apple 1-2-3-4-5-6 and OWC 7-8-9-10-11-12. And it worked. Apple tells you how to put different modules in the best sequence to optimize performances but they don't tell you how to integrate Apple-approved modules in the slots, except for the suggestion of not mixing different sizes and R-dimm with LR-Dimm
Upgrade to 2019 | enfamale | Pro Tools 2019 | 2 | 02-12-2020 04:05 AM |
Upgrade from 12.4 to 2019 | emperor of mars | Pro Tools 2019 | 2 | 01-29-2020 08:33 AM |
PT 2019.6 at 96Khz mutes random regions | Stephen Webster | Pro Tools 2019 | 2 | 10-22-2019 12:43 PM |
Upgrade 2019 | basslik | Pro Tools 2019 | 3 | 10-06-2019 03:20 PM |
