Old 07-14-2005, 12:22 PM
SamuelAdams SamuelAdams is offline
Default the mp3 option cannot be enabled
the MP3 option cannot be enabled because: the "Codecs" folder could not be found within the "Pro-Tools" folder.
i got this when trying to export a wave file to mp3 format, did the installation miss this part when i installed pro-tools or is this something i need to purchase as an add-on or what.
thanks-
Sam Adams
Old 07-14-2005, 02:15 PM
Moz Moz is offline
Default Re: the mp3 option cannot be enabled
In iTunes go to Preferences/Importing/Import Using/(choose)MP3 Encoding (select rate; maybe 160kbps) and then OK.
Drag the wav file to iTunes Library, select (tick) the song, go up to Advanced and select "Convert selection to MP3" and be happy!
Old 07-14-2005, 02:18 PM
Gkyaun Gkyaun is offline
...or instead of 160, try 192, or higher.
Yes, the mp3 does have to be purchased extra. iTunes does it for free.
sincerly mine, always and forever,
Gkyaun
go left next time
Old 07-14-2005, 02:46 PM
jonnyrocker jonnyrocker is offline
I encountered this once as well. You do have to check an extra box when installing PT to install the MP3 option codec. You can choose to install the update or 30-day demo version.
Since you now already have PT installed, you can re-run the installer and only choose to install the mp3 option and nothing else.
Old 07-18-2005, 10:25 AM
thank you all for your responses, very kind of you.
-Peace!
mp3 option cannot be enabled emergems Pro Tools M-Powered (Mac) 0 08-31-2011 08:50 PM
mp3 option cannot be enabled ztone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2010 09:21 PM
Help - MP3 option cannot be enabled.... Hercules Pro Tools M-Powered (Win) 3 07-18-2010 05:33 PM
mp3 option not enabled on pt8 villagesound Pro Tools TDM Systems (Mac) 12 05-21-2010 10:56 PM
The MP3 Option cannot be enabled, please help!! arasia99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-28-2003 09:20 PM
