keyswitching in Structure Free - conversion problems
Hello all,
I just downloaded Structure Free, and I converted some old Giga samples to EXS using CDXtract so I can use them in Structure. They work great, except when I load a patch in Structure that has keyswitching, the keyswitching doesn't work. I can see that Structure loads all the different samples from all the different key switches, but I can't switch between them. I've seen how with the samples that come with Structure, the keyswitch keys are blue. I don't see any blue keys. I'm using Structure Free, so I can't go in and see how samples are mapped or anything. I tried converting to Kontakt format too, same results. Is this some limitation of Structure Free, or is there something I'm doing wrong? Thanks, cakes |
Re: keyswitching in Structure Free - conversion problems
filosofem
Aaron Mulqueen - 001 HD Native |
Hi filosofem,
Thanks for your reply. Not to press you, but is that a guess, or do you know this to be a fact? cakes |
(removed double post)
A deduction based on the Comparsion Chart.
filosofem
Well, I emailed tech support to ask, so we'll see what they say. No phone support for Structure Free.
Structure Free doesn't support Keyswitching. I installed Structure Free for you and my deduction was correct. In fact I'm surprised you can do anything with that. In other words, either Structure or Structure LE would be your best bet. And no I don't know whether Structure LE supports Keyswitching.
filosofem
filosofem,
Thanks for checking. The annoying thing is that the stock sounds included with Structure Free *do* have keyswitching. Very misleading. I will still await tech support's official reply. cakes |
Ahhh... yes, let me rephrase, digi encypted patches supporting keyswitches can be played however can't be edited nor created.
filosofem
Well, I just heard back from Tech Support, and they say it's a bug and will be addressed in future releases. So we'll see.
cakes |
Structure Free problems. | StephenMidgley | Pro Tools 11 | 1 | 07-26-2013 07:39 AM |
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
iLok problems for structure...reverted to structure free | thisistruth | Pro Tools 9 | 4 | 12-07-2011 08:04 AM |
Structure Keyswitching Video Question | macaholic | Virtual Instruments | 2 | 01-30-2010 06:06 AM |
Hyrid, Structure Free & Xpand! Problems | GFLujan | Virtual Instruments | 2 | 08-07-2008 02:02 AM |
