Old 05-28-2009, 05:35 PM
cab7220 cab7220 is offline
Default PT8 Zip/Downloader issue
when i go to download the Windows upgrade with the Pro_Tools_LE_v8_56243 zip file then extract it. it says there are no files to extract. Also it just says it has an error wen i use the downloader. then i tested out downloading some other stuff like loops and samples,they all worked perfectly fine on the downloader and straight zip files that i was able to extract.
anyone else have this problem with the downloader error or 0 files to be extracted?
Old 05-28-2009, 05:51 PM
sw rec sw rec is online now
Default Re: PT8 Zip/Downloader issue
No, mine went off without a hiccup. What's the size of the zip file? How fast a 'net connection did you have when you downloaded it? (Mine took 5 hours over a dsl...)
Old 05-28-2009, 06:06 PM
thats the problem the size of the zip file is 0 bytes. and i'm assuming that is why there is an error when i try it through the downloader.
Old 05-28-2009, 06:10 PM
The zip file should be around 3.5 GIGS. Maybe something glitched when you were downloading???? Try downloading again.
Old 05-28-2009, 06:57 PM
just logged inot my digi account and when i downloaded the installler, it had the 3.5Gb besdie the compressed file folder. so its all good now :)
Old 05-29-2009, 09:01 AM
Some 'net connection protocol "times out" if you spend too much time on a download,
especially one that takes 5 hours! Glad you got it worked out. Enjoy PT8!!!
Old 05-29-2009, 06:22 PM
scottedog scottedog is offline
I had the same problem. They had to send it to me via DigiDelivery. I suspect they had a glitch on their end.
Scott.
ScottedogStudios on ReverbNation
Old 05-29-2009, 08:03 PM
TOM@METRO's Avatar
Yes, there have been some glitches, the trick is to try again rather than trying to spend to much time fighting a corrupted download. Make sure you have the latest version of WinRar or WinZip.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-30-2009, 07:42 AM
Tried for a week with no luck until Digi set me up.
Nice looking set up, btw.
Scott.
10.3.2 Mac downloader doesn't work with latest version of Java nedorama macOS 3 10-21-2012 06:33 AM
DIGIDEDSIGN - What's The Problem With the Downloader?? And a Rant... ctyelvis macOS 4 01-30-2011 08:54 AM
Pro Tools 9 download from avid downloader eighteez Pro Tools 9 13 11-22-2010 02:42 PM
PT8 downloader crashed, now I can't use activation code again? Tim R. Pro Tools TDM Systems (Mac) 1 06-17-2009 08:17 AM
