A good sequencer plugin for PT?
I was wondering if anyone knows of a good sequencer RTAS plugin for PT LE? (if it even exists).
I'm so dissapointed with the PT midi situation. There there has to be a good tight sequencer that will work the time stamping feature of my AMT 8 interface. Any ideas?? Thanks! Voltech/// |
Re: A good sequencer plugin for PT?
Years ago (on a Quadra system) I ran Performer and ProTools in sync. It was a bit of a confusing hassle to set that all up, but then it worked quite well. It's been so long that I don't remember any of the details of how you do that, but I would think that this can still be done with modern systems. I don't do any sophisticated midi stuff these days, but I do recall that Performer seriously outperforms the ProTools midi sequencer.
its a hassle, but your best bet, IMHO,
is to use logic for MIDI stuff, which will allow you to take advantage of the full capabilities of your MIDI interface |
I use a G4 DP under OS9 with Digi 001, Opcode StudioVision Pro in MIDI mode only, and ProTools, OMS with the Gethree serial port connected to my Opcode 128X midi interface.
I edit all the midi stuff in SVP, with PT running in background as a mixer only. When my sequence on SVP is ready, I import it in PT. The external synths, Soft SampleCell and a SampleCell card are all mixed in PT. It is also possible to sync SVP and PT, using IAC communication bus in OMS.
Jean-Luc Marechal G4 DP DualBoot 1.25 GHz / Digi 001 |
thanks for the tips guys..
voltech |
Good keyboard sequencer | myronfuller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-24-2004 04:21 PM |
How good is PT sequencer? | narleysoundz | Pro Tools TDM Systems (Mac) | 19 | 03-19-2002 01:54 PM |
Please help...-Anyone good with the PTLE sequencer? | voxpitch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-10-2001 08:35 AM |
Good Sequencer!!! | Record-n-Play | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-24-2000 01:41 PM |
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-05-2000 12:29 AM |
