Old 12-01-2021, 01:40 PM
dominicperry dominicperry is offline
Default Re: When your internet is down so is ProTools
A bit like subscription software, this is an insidious problem that is very hard to stop. Even software which has a local license seems to go to the internet to check that you aren't using it on multiple machines. And quite often you have no knowledge that it is doing so until things stop working.
In my case, Audirvana, paid for as a one-off permanent license, installed on one machine, decided to stop working when it couldn't get to the net for more than 30 days.
Most Apple apps seem to do the same thing, despite the fact that you can run them on as many machines as you have logged in under your own Apple ID.
Dominic
Old 12-01-2021, 01:56 PM
Eric Lambert's Avatar
Little Snitch shows that, when opening PT it largely traffics for iLok, everywhere.avid.com, and my.avid.com. One, or all, of those was certainly the hangup yesterday.
When internet traffic slows down here I'll disconnect the internet (keeping the connection between my computer and router intact so that it emulates yesterday's conditions) and try to view where, specifically, it's held up.
edit:
In Little Snitch, under ProTools, it lists:
-everywhere.avid.com
-identity.avid.com
-my.avid.com
-www.avid.com
-apps.avid.com
-api-us-east.everywhere...
Which of these can I safely block? I don't use any collaboration services with ProTools, nor do I use the Avid Manager (whatever it's now called) to update PT-related apps and plugins.
Old 12-01-2021, 02:02 PM
Ben Jenssen's Avatar
I use Radio Silence - $9 only, and very simple to use. Mac only. I'm shure there are win equivalents.
I can't guarantee it works on this specific problem, though.
Old 12-06-2021, 09:55 AM
-identity.avid.com
-my.avid.com
-www.avid.com
-apps.avid.com
Anyone wanna shed some light on which of these IPs above can safely be blocked if we're not using collaboration features or Avid Application Manager.
Old 12-06-2021, 10:30 AM
Well, who would have thought a local application needed 6 different server communications to run. What a ridiculous arrangement.
Only Avid can tell you what's on the end of each of those URLs - just because there is or isn't a website on some of them doesn't tell you what application gateways are hidden on a particular port.
You could use trial and error - block them all and see what stops working.
Dominic
  #16
Old 12-06-2021, 11:24 AM
That's probably what I'll do, but others have already experimented and blocked the appropriate IPs so I thought I'd wait for that. There's no rush -- my internet hasn't gone done again since last week (knocking on wood).
  #17
Old 12-06-2021, 12:03 PM
weezul weezul is offline
Here's my littlesnitch, everything has worked fine for a long time:
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
  #18
Old 12-06-2021, 04:23 PM
Thx!
  #19
Old 12-07-2021, 03:53 AM
You don't need to connect any of those IPs for PT to work so it's perfectly "safe" to not have any outbound connection. You can block them all.
As mentioned the problem isn't that those IPs aren't reached, the problem is that the entire machine "thinks" you have internet and therefor endlessly waits for a response before it times out.
Just make sure you reject instead of block otherwise the machine won't know that there's no one on the other end.
Just rejecting the AVID specific ones might fix the slow PT start but there will be plenty more apps incl the OS itself that might do a super slow launch because the same problem that I mentioned earlier in this thread applies to all of them in case of an internet outage but the router still connected.
  #20
Old 12-07-2021, 04:00 AM
You'd be surprised about the amount of metrics and other third party tracking beacons working in the B/G 24/7. I have an advertising and tracking blocker running on our firewall and it's literally thousands of trackers and metrics connections blocked every day from all machines, phones, ipads etc. etc.
I do this in the firewall as trying to "whack-a-mole" all those on every end device is a like fighting wind mills. Even my Samsung flat screen (tries to) connects to a ton of servers every minute I guess to send viewing metrics to third parties. Looking at those logs every now and then is scary.
ProTools first internet Bigbone Pro Tools | Intro Discussion 2 09-26-2018 09:14 AM
protools and the internet bluski g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2007 02:08 PM
the internet and protools anthony brown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-26-2006 08:56 PM
Internet and protools stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2004 03:15 PM
Using MAC 867 DP with Protools & Internet KasticK Pro Tools TDM Systems (Mac) 4 11-27-2002 05:51 AM
