PTF plugin latency dilemma
How can I hear my processed guitar using bundled plugins I got with my Focusrite 2i2 with my Pro Tools First using low latency? With low latency on I hear an unprocessed clean guitar, very sterile. Please be patient, I am a new user of this software. I am debating on whether or not to go back to using a Tonelab desktop directly in to the 2i2 as I have had no problem with that at all, obviously.
Re: PTF plugin latency dilemma
What you are describing is exactly what Low Latency Monitoring does:
Low latency monitoring will mute the output of any record-enabled tracks in Pro Tools so that you only hear the direct signal coming from your interface. Low latency monitoring is designed this way to prevent the latent signal that travels from your interface, through your DAW, and back out to your interface from mixing with the direct signal so that there is no delay. If you are getting unacceptable latency with it turned off, then your audio interface is the culprit. I’m not sure what kind of system you are on, but in your Focusrite settings, try lowering the buffer size, which should lower the latency. If you start getting clicks and pops in the audio, then the buffer is too small for your system to handle and you will have to increase it. |
plugin latency? | digidesigner | VENUE Live Sound Systems | 5 | 09-03-2009 01:24 AM |
Plugin latency | Mac Shack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-07-2005 09:44 AM |
Plugin Latency | derF | Pro Tools TDM Systems (Mac) | 1 | 04-05-2003 07:12 AM |
Plugin latency | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-13-2002 06:32 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
