Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-17-2025, 03:32 PM
shawnhonsberger's Avatar
shawnhonsberger shawnhonsberger is offline
Default Copy Trims and Delays from Output Group to Another in Profile?
I see that you can copy all eq filters from one channel to another in another output group, which is super handy. Can you also copy delays and trims?
I'm trying to replicate an output group from scratch, but I was curious if there was any shortcut to copying all delays and trims or if everything needs to be done manually - clicking back and forth and manually matching.
Thanks!
Be safe and well,
Shawn Honsberger
Argyle Street on Apple Music
System Details:
Apple Mac Studio M2 Ultra 24 Core CPU, 60 Core GPU
192GB Unified Memory, 4 TB SSD
Apple iPad Pro M2 (12.9-inch) (6th generation)
I/O + Control Surfaces:
AVID Pro Tools | MTRX Studio (TB3 Native)
AVID Thunderbolt 3 Option Module:
RTL (96k): 1.2ms at 32 samples, 1.8ms at 64 samples
RTL (48k): 2.3ms at 32 samples, 3.6ms at 64 samples
AVID S1 EUCON Controller
Elgato Stream Deck XL
Software:
Apple macOS 15.3
AVID Pro Tools Ultimate 2024.10.2
AVID EUCON 2024.10
AVID Control 2024.10
Dolby Atmos Renderer 5.3.0
SoundFlow 5.10.1
Scheps MOMDeck
Apple Logic Pro 11.1.2
SoundID Reference for Multichannel 5.12.1
Drivers:
AVID MTRX Studio Firmware 1.1.5.1
AVID DADman 5.8.0.8
AVID DADTBDriver CoreAudio 1.2.2
Dolby Atmos 9.1.4 Monitoring:
Kali Audio IN-8 V2 (9)
Kali Audio WS-12 V2 (1)
Kali Audio IN-5 (4)
Old 01-18-2025, 05:41 AM
creativecontrol's Avatar
Default Re: Copy Trims and Delays from Output Group to Another in Profile?
No, but you can use the Import from Profile function (which is similar to Import Session Data in Pro Tools) to bring bits into your active monitor profile. Just bring in the desired output set a few times - which will already contain the trims and delays, then modify them appropriately.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-18-2025, 09:11 PM
Thank you, Jeff!
Be safe and well,
Shawn Honsberger
System Details:
Software:
Apple macOS 15.3
AVID EUCON 2024.10
SoundFlow 5.10.1
Scheps MOMDeck
Drivers:
AVID DADman 5.8.0.8
Kali Audio IN-5 (4)
Master vs Cue in DADman Monitor Profile Group Mode? ric982 Pro Tools | MTRX & MTRX Studio 7 11-16-2023 06:23 PM
192 I/O Output trims: amount of amplification Mark Ziebarth Pro Tools TDM Systems (Mac) 6 01-08-2014 04:18 AM
HD Omni Monitor Controller/Output Trims Jantzen Pro Tools HDX & HD Native Systems (Mac) 0 08-03-2013 09:57 AM
192 I/O - Analog output trims not working? trian Pro Tools TDM Systems (Mac) 0 08-12-2009 02:46 PM
Problems with Output trims on the 192 I/O DigiPanzer Pro Tools TDM Systems (Mac) 1 06-19-2002 11:57 AM
