Dual Monitors
Is it possible to run a dual monitor setup with Pro Tools LE (Mix + Edit Windows)?
How do you go about doing this? What do you need? Cheers Joe
Digi 001 Dell 2400 Pentium 4 3.0Ghz 512mbs Ram Reason 1.0 |
Re: Dual Monitors
You will need a dual head video card.
I beleive the current one being popularly recommended is the ATI 9600, but there are lots of others. I have the ATI 9200 SE and it works great. Depending on which monitors you are using, you might need a DVI to VGA adapter, but some of the cards come with them (mine did). As for how to set it all up, a search of this forum for "dual monitors" over that past year should turn up a ton of threads where that has already been addressed.
Re: Dual Monitors
You need a card that supports dual monitors - most new ones do. The included software lets you configure the rest (monitor one, monitor two, freq, etc..), then you simply drag the screens around the way you like them.
At least 6.4 opens the sessions the way I left them, screen-wise. Highly recommended.
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
Re: Dual Monitors
I use a Matrox Millenium G450 - it's a bit older but I am getting close to buying this puppy and running 3 =>
King of Cards My 2 monitors are NEC Multisync 19" LCD displays - I'm looking around for the 3rd (want them to be identical you understand... I couldn't work with a single display any more... |
Re: Dual Monitors
Matrox Millenium G550 works fine here : Athlon processor, Asus A7N8X MoBo, 2 different TFT screens.
Very simple. |
Dual Monitors w/ OS 9.x | bassist | Pro Tools TDM Systems (Mac) | 1 | 02-26-2003 02:32 PM |
Dual Monitors in PT6 | pxpx83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-18-2003 07:55 AM |
Dual Monitors? | hzway | Pro Tools TDM Systems (Mac) | 8 | 02-03-2003 08:45 PM |
002 with dual monitors? | scardanelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-23-2002 02:35 PM |
Dual monitors | mentalmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-15-2002 09:14 AM |
