Pro Tools 11 trial activation filed
Hi!
I new in Pro Tools community. And I would easy start with demo version of Pro Tools 11. But I'm not lucky boy, I think. I spent 48 euro for iLock bought. I activated trial licenses with iLock. When I try activate Pro Tools 11 trial I get error message as imaged on picture below about License server Error!. Result is: - I spent money for iLock - I tried activate Pro Tools 11 for the last night. I spent my own time for 5 hours at least for "dancing with a tambourine" around PT 11 activation. Yes! I googled about problem around internet. I reinstall iLock software 4 times!!! My iLock connected to my Mac Book pro directly!!! But I don't get positive result. - Now I continue spent my work time (it means, that I lost my money!) and try to solve problem. In this case I would like to ask ProTools community. Is ProTools really so terrible software and problem comes from the start? Why I can't send e-mail to Avid support and why I must make payment ~$40 for "talking by phone" about trial version (I did not decide I will buy this software or not)? Does ProTools community think that this is adequate support position for their users? Last and main question! How I can activate this is software? Best regards AlexSander |
Re: Pro Tools 11 trial activation filed
Have you installed the latest iLok License Manager software - you need that to make the iLok work. Have you properly setup an iLok.com account? You need to do that before activating the PT11 trial. And when setting and being asked for your account ID DO NOT use the serial number that's on the iLok. The account ID is something you make up yourself to identify yourself to the system. For example I used a name and number combo.
Most importantly - is your iLok plugged into a working, powered USB port? If you're on a current Mac they tend to have USB3 ports and those have been known to cause issues with iLoks that can be solved by using a powered USB hub between the iLok and the computer. |
Thank you for the answer. I use latest iLok software. I downloaded it at evening, yesterday. Version of license manager is 2.3.1.1244. And especially than you about problem description with USB3. I plug-in external powered USB hub and Pro Tools starts without any problem! I think, PACE company must be closed and software engineers must looking for the other job. I think, that problem not in Mac's USB3 port, but with iLok chipset. Anyway, thank you very much! Good luck! Best regards Alex |
If there's a problem, I'm fairly certain it has everything to do with the cable in between...
They may know about it but it's not their issue to solve - they have nothing to do with the USB2 spec. iLok2 works perfectly fine on USB2.
USB3 might be finally up to FW400 at least, but to very least it should behave well with older USB interfaces. (the pun here is that USB2 = 480 and FW400 = 400 but in real life FW beats USB2 anytime, at least whenever audio recording is concerned. USB3 might just finally beat first-generation FW400 in real life)
session file back are scattered and not filed neatly how can I keep them tidy | Weird Audio | Pro Tools 10 | 1 | 12-06-2012 03:37 AM |
PT10HD Trial and Trial Licence Not seeing! Urgent!! Have session in 2 Hours!!! | mozart | macOS | 6 | 12-29-2011 08:05 PM |
Activation code for Structure 14 day trial not available | sonicland | Virtual Instruments | 3 | 02-07-2010 02:37 AM |
No Trial License Activation | AG | Pro Tools TDM Systems (Mac) | 7 | 12-11-2006 05:47 PM |
working with 2 pairs of near filed monitors | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2003 12:22 AM |
