PT 10.3.4 upgrade advice
I just installed my new HDX system with PT 10. After installing 10.1 it told me there was 10.2, then 10.3, etc...I'm getting frustrated by having to keep doing clean installs and am wondering if it really makes a difference? I have loads of plugins so worry about having to spend time reinstalling them.
1. When you uninstall a version of Pro Tools do you loose all your plugin installations or do they stay on system drive and/or does Avid Plugin folder remain intact? 2. What is the risk of not doing a clean install of new version? Thanks in advance for your help and advice, I'm sure someone else is experiencing this same frustration.
www.theoaronson.com Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Catalina (10.15.7) w/ Pro Tools Ultimate 2020.12 Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O |
Re: PT 10.3.4 upgrade advice
And for .1 .2 .3 releases, I'd just install them over top of the previous. FWIW, I found 10.3.3 to be a really good one for me. BTW, I'd just wait a few weeks and do the OS and PT updates all at once if you plan to go to 11. |
Hi I would goto version 10.3.5 directly and don't forget that the "AIR" Virtual Instruments are a separate installer amd should be version number 10.3 found here : http://secure.digidesign.com/service...rticleId=43572 And PT 10.3.5 here: http://avid.force.com/pkb/articles/D...-3-5-Downloads Happy installing
Thanks for all of this guys. Will try to get to 10.3.5 and see how it goes.
PS - you find yourself having issues with TL Space Reverb Plugin too once you upgraded? I'm having lots of trouble recalling sessions that had TDM version of it now that i only have access to RTAS versions :/
Need Advice to upgrade to PT LE9 | [email protected] | Windows | 2 | 06-03-2011 02:19 PM |
Advice Please on LE to HD Upgrade... | pguy | Pro Tools TDM Systems (Mac) | 12 | 12-16-2009 09:10 PM |
Upgrade Advice | ralfddd | Pro Tools TDM Systems (Mac) | 1 | 09-14-2006 09:16 AM |
Advice: Mix to HD Upgrade | Mount Royal | Pro Tools TDM Systems (Mac) | 15 | 09-21-2005 07:11 AM |
Need Upgrade advice | DCatLDS | Tips & Tricks | 1 | 06-05-2003 09:08 PM |
