Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-01-2022, 05:23 AM
pm mastering studio's Avatar
pm mastering studio pm mastering studio is offline
Default Carbon Pre Mic control from within ProTools not working (showing)
Just recieved my new Carbon PRE !
Configured avid Carbon Centre to connect the Avid Carbon + Carbon PRE
All seems ok
* ProTools Playback engine set to Carbon Exanded.
* but in Hardware configuration in ProTools I only see Avid Carbon so not the additional CARBON PRE
* When I create a single mono track and select the input to the CARBON I can control the Pre-amps and you see the controls in the mixer window
BUT
When selecting an input from the Carbon PRE this option is not shown (see pictures)
also not able to select 48V or inpedance from within protools
Do I forget something ?
with kind regards
Philippe Meiresonne
(Belgium)
http://www.pm-mastering-studio.com
SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4
ProTools Ultimate 2024.3| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|3x PRE | 2x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Acid HD I/0 16/16 Analgue
Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System
System 2 : Project System - ProTools CARBON Running Sonoma 14.4
MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE
Old 12-01-2022, 09:51 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Default Re: Carbon Pre Mic control from within ProTools not working (showing)
Hey Philippe!
A few things...
1 - You do not need to set up mic pre control for Carbon r Carbon Pre in Peripherals, Pro Tools knows when you're PB Engine is Expanded that you will have mic pre control over inputs belonging to the Carbon or Carbon Pre.
2 - Your input looks like it is set to Line. You cannot access +48 or Z unless you are set to Mic input AND you have a cable plugged in. Otherwise they appear blank... might be better if they were just dimmed rather than missing.
3 - There are currently no Carbon Pre setting in HW Setup, so you are not missing anything.
I think that's it... enjoy the new Pre!!! Tell all yer friends...
Mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 12-01-2022, 12:49 PM
Originally Posted by MCorbin View Post
Hey Philippe!
A few things...
Hi mark.
But the carbon pre settings are not controllable in PT. They are not showing in the mixerview. They do for the carbon interface but as soon as you select the input of the carbon PRE the settings disappear. Even when an XLR/Jack (on any input of the PRE) is inserted. According to your post PT should automatically recognise the 8 additional pre-amps and made them controllable in PT, but it doesn’t show. You can select them and then manually set the settings on the interface itself but not through PT.
This is indeed the case. Thanks
OK
Mark
Philippe Meiresonne
(Belgium)
Old 12-01-2022, 02:27 PM
MCorbin's Avatar
Ah, I see... are you on the current version or Pro Tools? There was a lot of work done in this area for the Pre release.
m
Mark Corbin
Old 12-01-2022, 10:44 PM
Do have the latest version 2022.10 installed
Both protools studio and protools ultimate (on 2 separate systems)
Philippe Meiresonne
(Belgium)
Old 12-02-2022, 05:36 AM
creativecontrol's Avatar
Greetings,
Try blowing away your IO Setup and see if the remote mic pre controls behave then.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-02-2022, 08:55 AM
Oke guy's,
thanks for the support. Found the solution.
Had to through away the preference-settings (PTPref) and now all works !
thanks again !
with kind regards.
Philippe
Philippe Meiresonne
(Belgium)
Old 01-13-2023, 12:54 PM
Nielsnielsen Nielsnielsen is offline
Same here. Trash pref files and restart PT. Worked for me. I used that free program someone wrote to delete all files.
I LOVE carbon+pre. Sounds so good and works soo good. Only had to do that pref trash.
S1 + dock to control Carbon monitor levels? wickett Pro Tools | Carbon 5 01-05-2023 06:53 AM
What happens to Protools Carbon Sub? digiot Pro Tools 6 05-12-2022 09:10 AM
Carbon Preamp Control Chris August Pro Tools | Carbon 6 11-02-2021 03:02 PM
Carbon support plan in the Avid Control application. Seayoung Pro Tools | Carbon 1 08-31-2021 09:40 AM
FS: Protools Carbon Technog0d Buy & Sell 2 05-10-2021 10:25 AM
