Imported Audio DYN Dark Blue
Every time I import a new .WAV file into my session it's showing up with the DYN button highlighted in dark blue. This is causing no levels and no audio to be played from the tracks. The audio that's imported with my video is having no problems.
I'm using 24but / 48 KHz on my Pro Tools session. The .WAV files have a bit rate of 4608kbps. However, if I try to change the rate on a new Pro Tools session before I import I then get an error saying my imported audio is at a different sample rate than my session. Can't find anything online on how to fix this issue. Any advice would be appreciated! |
Re: Imported Audio DYN Dark Blue
The Dyn button indicates that the track is set to use dynamic voicing. Pro Tools will assign voices dynamically as required in the session. If the Dyn button is blue, that indicates that the session is out of voices and the track can’t be played. You can delete or deactivate unused tracks, or you can move the track you want to hear higher up in the edit window and it will get a voice assigned to it for playback.
"DYN" turns dark blue when opening a session | timon19 | Pro Tools 11 | 6 | 05-11-2018 05:22 AM |
Camel Audio Going Dark July 7th | DonaldM | Virtual Instruments | 9 | 11-19-2015 05:15 PM |
Unmute Mono Channel Colored Dark Blue | ReynaldoPena | Windows | 0 | 11-24-2012 06:35 PM |
Instrument Track buttons have turned dark blue | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-10-2007 05:40 PM |
Instrument Track Buttons on Mix Window have turned Dark Blue | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-15-2007 04:20 PM |
