Old 09-25-2022, 01:49 AM
unkJE's Avatar
unkJE unkJE is offline
Default Last Day! US $19.99 for SSL LMC+
https://www.pluginboutique.com/
80's Drums and Beyond
The SSL LMC+ replicates the sound of an SSL 4000E console's reverse talkback function, a.k.a. the Listen Mic, which included an integrated compressor to safeguard against overloads and make quiet speech intelligible. It was the Listen Mic Compressor, combined with the SSL 4000E's built-in noise gate, that was the genesis to the gated-reverb drum sound that dominated the '80s.
The LMC+ plug-in eclipses the original hardware, providing you with advanced functionality that wasn't present in the original console, such as external sidechain capabilities, highpass filters and lowpass filters, and Scoop and Split functions. And thanks to its intuitive controls, the LMC+ is a breeze to use. If you want to smash everything back to the 1980s, the LMC+ is the plug-in to do it with.
The LMC+ plug-in takes the vaunted SSL Listen Mic Compressor from the center section of an SSL 4000E console and enhances it with modern features derived from SSL's LMC+ 500 Series module. An external sidechain enables you to trigger gain reduction with an external source or signal, while variable highpass and lowpass filters allow you to tailor which frequencies trigger the compression. You also get Scoop and Split functions. Scoop phase-inverts your wet signal, while Split engages a bandpass-subtraction mode.
There is also a Mix control, which makes parallel processing a piece of cake. If you enjoy slamming audio into oblivion, you'll find a zillion uses for the LMC+.
Features
• Replicates the sound of an SSL 4000E console's Listen Mic Compressor
• Fixed attack and release curves are tailor-made for ambient drums
• External sidechain triggers gain reduction with an external source or signal
• Variable highpass and lowpass filters tailor which frequencies trigger the compression
• Scoop button phase-inverts wet signal
• Split button activates bandpass-subtraction mode
• Mix control makes parallel processing a piece of cake
System Requirements
Mac
• macOS 10.12 Sierra - macOS 11 Big Sur (M1 Mac not yet supported) (64-bit only)
• Intel Dual-Core Mac running at 2.4GHz or higher
• 4 GB of RAM minimum (8 GB of RAM recommended)
• AU, VST2, VST3, AAX Native
Important Note: SSL products are compatible with M1 Apple Silicon Macs via the use of Rosetta.
Windows
• Windows 7 - Windows 10 (Windows 11 not yet supported) (64-bit only)
• Intel Core 2 (or comparable) CPU running at 2.4GHz or higher
• VST 2, VST3, AAX Native
Please Note: A FREE iLok Account is required for the authorisation of this software.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 09-26-2022, 02:44 AM
martthie_08 martthie_08 is offline
Default Re: Last Day! US $19.99 for SSL LMC+
nice, but there are literally hundreds of plugin deals out there every day. I would advise to post these deals in the main "The MEGA Plugin Deals Thread" as not to clutter up this sub-forum.
Old 09-26-2022, 05:37 PM
unkJE's Avatar
Originally Posted by martthie_08 View Post
...not to clutter up this sub-forum.
Not totally convinced about posting where you suggest, because the individual deals don’t get mentioned in the heading, whereas:
said it all – it told you all you needed to know, without any extra clicking.
$19.99 for what is listed today at $130.90 deserved its own Thread.
You can rest easy: there’s no law demanding you click on Threads that don’t interest you!
Old 09-27-2022, 11:52 PM
audiolex1 audiolex1 is offline
Features
System Requirements
Mac
Windows
Thanks for your post on this deal.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 09-27-2022, 11:53 PM
YEP!
Almost every plugin
HTML code is On
