Old 01-04-2004, 11:30 AM
bigdude bigdude is offline
Default problem with mp3 export and btd - help
running 6.1 tdm on winxp, fat32 drives
it does the bounce but when it goes to mp3 process i get this error -
"Cound not complete the "Bounce to Disk.." command because: Priviledged instruction executed in user mode"
i can import mp3's no problem...
any ideas?
thanks!
Old 01-04-2004, 11:43 AM
Default Re: problem with mp3 export and btd - help
ok, found this in answerbase:
"Privileged Instruction executed in user mode" error when attempting to bounce or export to MP3 with Medium or High quality encoding speed.
This is a known issue with Pro Tools/Pro Tools LE 6.1, 6.1.1.
anyone know of a workaround or fix?
thanks!
Old 01-04-2004, 02:43 PM
nikki-k nikki-k is offline
Hi!
Using mp3 as the format when bouncing to disk, I have used the set-rate option, and simply changed ONLY the rate. I leave the "quality" parameter at the default, which is medium quality I believe. No problems with doing it in this manner so far for me.
Alternately, and albeit annoyingly, a workaround I use occasionally- I use CDex.
Normally, I like to BTD to wav, so as to have a nice hi res render. Instead of doing a second bounce for mp3, I will use CDex to do the conversion, since it takes significantly less time than sitting through ANOTHER bounce just for a different format. CDex is free btw There are other solutions as well of course
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
export problem GStyle Pro Tools M-Powered (Win) 2 04-24-2006 08:10 PM
MP3 export problem K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-15-2005 01:45 AM
MP3 export problem ...please help Lanois WannaB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-05-2005 09:43 AM
5.1 MP3 export problem ? Jussi Tegelman Pro Tools TDM Systems (Mac) 0 10-29-2002 09:52 PM
little problem with Pt to omf export Richard Fairbanks Post - Surround - Video 5 06-21-2002 01:35 AM
