Old 07-29-2002, 02:50 PM
dirktones dirktones is offline
Default Sony EQ vs Waves Linear EQ in mix
What is your opinion on the Waves EQ vs Sony Eq in the context of a mix (rather then in mastering) on stuff like drums, vox, etc.
Old 07-29-2002, 05:26 PM
Jules Jules is offline
Default Re: Sony EQ vs Waves Linear EQ in mix
The Sony EQ has a sample delay of 4 samples.. I thought the Waves one had a very large sample delay... or am I confusing that with a mastering version.... I duno..
[img]images/icons/shocked.gif[/img]
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 07-30-2002, 02:48 AM
Corey Shay Corey Shay is offline
The linear phase eq is the mastering eq. It seems that is what dirktones is referring to. I tried the waves demo once on guitars and I was quite impressed. I felt both the sony and waves held up very well, but unfortunately the delay on the waves was much too high. I didn't spend too much time comparing because of the delay problem, but I was certainly intrigued. If I bought the Waves linear eq, it might be more trouble than it's worth to get it in time with the rest of my tracks.
Old 07-30-2002, 04:20 AM
jackruston jackruston is offline
Corey is right. The delay is just too great. It's fine if you just have to nudge things a tiny bit, (and you dont really have to bother with 4 samples on a guitar) but when you're dragging regions all over the place it's a nightmare. The sony is also easier to use.
J
Old 07-30-2002, 04:53 AM
uno1234 uno1234 is offline
I don't like the Waves linear EQ because it's sound is good but overrated, and it's so darn hard to use. Not only is there a very large sample delay, the plug takes up an excessive amount of DSP and functions very slowly. The controls are slow to react, and there is a pop as Waves usual when you cut in and out the low freq. The Sony Oxford GML is way way waaaayyyy better in terms of functionality, and arguably comparable, if not better, in terms of sound. At least it's easier to use, so as a result, I naturally EQ better!
Old 07-30-2002, 05:50 AM
etherize etherize is offline
I wonder if Jules is Beta testing the upcoming GML EQ....just smile if the answer is yes Jules [img]images/icons/grin.gif[/img]
I am putting off my purchase of the Sony EQ until Massenberg comes out... Hopefully it will be priced better...
Old 07-30-2002, 04:52 PM
JJ-SOUND JJ-SOUND is offline
The Waves Linear phase EQ is completely different type of EQ then Sony EQ or any other EQ like Waves RenEQ and many others.
Sony and the other introduce phase distortion, these filters are sometimes called minimum phase filters. on the other hand LinEQ and LinMultiband are based in linear phase filters. the only way to achieve this is by introducing a latency on the audio! the more the latency the higher resolution are the filters. The benefit of these filters are that the group delay of each frequency is constant and the phase is linear. this allows you to manipulate the sound in a very different approach. The Lin EQ is good if you are looking for new sounds and tools. If you are looking for "analog" type tools, you need to look at Sony and RenEQ
RenEQ has been doing very similar curves and controls. Also RenEQ has a very short latency...
Old 07-30-2002, 05:24 PM
<font size="2" face="Verdana, Arial">Thanks for clearing that. Here are my problems with Renn EQ: First off, when I try to cut lower midrange with it, say from close mic'd drums or muddy vocals, I find it a bit akward sounding. I also think the high end is brittle if pushed too hard. Most importantly, and I've seen others say this, it kind of puts an overall "haze" on the track it is used on. I've been using Filterbank with better results but am still looking for better. The Sony seems the way to go.
Old 07-31-2002, 12:40 AM
Mikey MTC Mikey MTC is offline
I think they're two completely different beasts and they're both brilliant. EQ is such a difficult thing to describe but here's my take on it:
The Oxford adds a colour and the Lin EQ is almost seemless. Recently I've been using the Oxford almost all the time, but the other day I had to remaster an old vinly recording from the 70's and the Oxford wasn't doing it for me. I pulled out the Lin EQ and it just made it sound right without sounding like it was doing anything. It added no signature to the sound.
I've almost come up with a personal rule that if something needs colour or warmth, go for the Oxford. If something is already very coloured and just needs ridiculously clean EQ without any attitude, the Lin EQ is the gun.
I'm so glad to have both!!
Old 07-31-2002, 01:41 AM
No ... I dont have HD (yet) - so I cant Beta test for GM. Although he did hook me up personally for his GML Sony version. Rocking guy that he is....
Sigh....its not all a bed of roses in beta land...
[img]images/icons/frown.gif[/img]
Very hard day with beta stuff today and all I need to do is mix! HArooomph!
[img]images/icons/mad.gif[/img]
Jules
London, UK
www.gearslutz.com
Non-Linear vs. Linear Reverb Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-04-2016 08:59 PM
ticks, pops, with Waves Linear Phase EQ on PT 7.4 spectrasound Pro Tools TDM Systems (Mac) 6 09-17-2009 07:08 AM
Waves Linear Low Band weirdness bbob Pro Tools TDM Systems (Mac) 6 06-08-2006 05:46 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 02:31 PM
Oh my just heard the Linear phase equaliser from waves! hokuspocus Pro Tools TDM Systems (Mac) 9 03-28-2002 03:53 PM
