Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-07-2021, 10:19 AM
Top Jimmy's Avatar
Default Re: Phantom Power MboxPro3
Originally Posted by JFreak View Post
There is also a practically free solution to the phantom power problem. As we all (?) know phantom power is fed between XLR pins 1 and 2, so if you make a custom cable that connects to your ribbon mic with pins 1 and 3 you are safe from phantom power and only downside is you are 180 degrees out of phase (which can be corrected later if necessary). No extra hardware needed, but no balanced connection either.
Janne, that’s not quite right. Phantom (+) is shared equally across pins 2 and 3 with pin 1 being the return (-). If you use a cable as described, it puts the ribbon more at risk because of a transient when patching or switching phantom on/off. Transients do couple through transformers and these are what permanently throw ribbons out of the gap.
James Cadwallader
Old 09-07-2021, 11:00 AM
JFreak's Avatar
JFreak JFreak is offline
I myself would not risk a ribbon with a custom cable, but every now and then have had to do MacGyver things when running out of cables/adapters. When I do something like this I do it with (cheap) condensers, not anything that costs thousands.
I thank you for commenting though, something like this is obviously not supported by anyone.
Janne
Old 09-07-2021, 03:06 PM
I must agree with James on how the voltage is applied. Once again, I doubt you will have an issue, but if the Phantom Blocker gives you peace of mind, by all means, grab one. Another option is to grab a passive mic splitter(Sescom, ProCo, Whirlwind) that has a transformer isolated output and use that(which again, will not pass DC). A splitter will cost about the same, but can also do double-duty.
BTW, if you are wondering why you would ever need a mic splitter, one good use would be to feed a vocal mic into 2 inputs(assigned to 2 separate audio tracks) and set the GAIN lower on one of them. If the singer happens to clip the hotter input/track, you would have unclipped audio on the other track
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
Phantom power optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-10-2003 09:19 PM
New to Phantom Power Derek S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-04-2001 08:14 AM
