Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 06-24-2021, 11:12 AM
off the wall's Avatar
off the wall off the wall is offline
Default HDX Classic? How to disable Hybrid in 2021.6?
How do you disable the Hybrid playback engine in PT 2021.6 and revert back to "HDX Classic" engine?
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.7.5 EFI, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, MacOS 11.6.1
Pro Tools Ultimate 2021.10 HDX, UA Octo PCIe card in external TB3 chassis, HD I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 06-24-2021, 11:17 AM
Default Re: HDX Classic? How to disable Hybrid in 2021.6?
Duh, I was assuming it would be a choice in the Playback engine popup. It's a check mark below.
Old 07-28-2021, 07:35 AM
Lundy North Lundy North is offline
Where is the Hybrid 'Disable' check box, I can't find it?
Old 07-29-2021, 10:33 AM
Dan IceWood Dan IceWood is offline
yep...**** out of luck there, previous version is your only option
Old 07-29-2021, 02:01 PM
TrentWilliams TrentWilliams is offline
Page 91 of the reference manual:
1 Choose Setup > Playback Engine.
2 From the Playback Engine selector, select your
audio interface:
• For HDX systems, use HDX for the Playback
Engine. Enable the Hybrid Engine option for
mixed HDX DSP and host CPU processing
for the mixer. Disable the Hybrid Engine option
to use only HDX DSP for the mixer
(HDX Classic).
Pro Tools 2021.7|Ultimate • MTRX Studio • HDX1 • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 11.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
No SRC in 2021.3.1 JanuS Pro Tools 2021 10 06-02-2021 08:55 AM
2021.3.1 innesireinar Pro Tools 2021 80 04-22-2021 02:31 PM
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 01:01 AM
