Old 05-20-2009, 03:01 PM
StinkyStan StinkyStan is offline
Default Hybrid FX routing.
Hi. Back again with another question.
Is there a way to effectively "squeeze" a chain of 4 insert FX out of Hybrid? What I would like to do is route both oscillators through Part A Inserts 1&2 and then though Part B inserts 1&2.
Thanks in advance.
Old 05-20-2009, 06:19 PM
Default Re: Hybrid FX routing.
What FX plugs has Hybrid got that the Pro Tools 8 Creative Collection FX plugs don't that you can not use with the Instrument track Inserts?
filosofem
Old 05-20-2009, 06:41 PM
filosofem
The Creative Collection FX plugins are great. That's not the issue. I was just hoping to find a way to process the sounds internally within Hybrid. I'm getting close enough I suppose. :)
Old 05-20-2009, 06:59 PM
Yes this is your only solution as I see it. Although Hybrid Parts A & B work together they're also independent. The max processing chain for Parts A or B is always going to be two minus Master Effects - Chorus, Delay and Reverb.
The AIR CC FX Plugs are the same as you'll find in any AIR VI.
filosofem
Hybrid 1.5.3 and PT 10 serio macOS 6 11-11-2011 08:29 PM
Hybrid iTwang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-12-2009 11:39 PM
Routing out Logic 1 & 3, anyone know basic Logic routing? soundonsound Pro Tools TDM Systems (Mac) 2 06-04-2008 10:42 PM
Hybrid Bug MiamiMusicMan Virtual Instruments 2 10-13-2006 02:30 AM
