Old 02-04-2007, 10:45 AM
emilano emilano is offline
Default Re: How to: select between two automation breakpoi
I agree this is something i often need to do quick and easy and it never is. I often end up highlighting all breakpoints between the two that I want to trim. Then using the trim tool usually will work. However, sometimes they are at slightly different levels and the trim tool then will move the entire volume of the track rather than just btw the 2 breakpoints.
bottom line: Would be very cool if in volume view there was a "tab to breakpoint" feature so that one could easily set up the selection area that you want to trim.
Old 06-23-2021, 11:21 AM
Skwaidu Skwaidu is offline
Default Re: How to: select between two automation breakpoints?
2021 calling: We still need this feature.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
Old 08-04-2021, 08:24 AM
Mefodiy Mefodiy is offline
Yes, I agree!
time tracking software
Old 09-04-2023, 02:22 AM
martthie_08 martthie_08 is offline
I believe this feature has been implemented in the newest version of ProTools, nice!
Old 09-07-2023, 06:42 AM
mattrixx mattrixx is offline
...and many chose to turn it off, as it was clashing with Tab to transients.
So, as with any DAW, some things are great and some things get in the way. YMMV.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Mute Automation Breakpoints redlinesound Tips & Tricks 2 08-29-2010 03:31 PM
Blue Automation Breakpoints? Quickkey Pro Tools TDM Systems (Mac) 1 12-27-2007 07:16 PM
Blue Automation Breakpoints? Quickkey Pro Tools TDM Systems (Mac) 4 12-24-2007 11:54 AM
Blue Automation Breakpoints? Quickkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2007 08:18 PM
CLICKS AT AUTOMATION BREAKPOINTS ukoomrann Pro Tools TDM Systems (Mac) 4 08-29-2005 06:53 PM
