Old 06-20-2002, 10:40 PM
Richard Fairbanks Richard Fairbanks is offline
Default Re: little problem with Pt to omf export
You can't, not even if you make every edit exactly on a video frame boundary. They should sound perfectly, however annoying they may be.
Call me by my real name, "Postman"
Old 06-20-2002, 10:46 PM
Michael Klinger Michael Klinger is offline
hmmm
Perhaps I need to clarify --
I'm only concerned that when I re-import the OMF (just to make sure that it works) for each clip (say thirty clips) there are 2 corresponding one frame clips (60 total) callled "sample accurate edit."
Just wondering why they little files are there and can I set it up my omf export to avoid them?
Michael Klinger
Tree Falls Post
Los Angeles
(323) 851-0299
mike@tfpost.com
www.tfpost.com
Old 06-21-2002, 12:03 AM
potatohead potatohead is offline
Avids require all audio edits to be on frame boundaries. These machines do not support 'sample-accurate' OMF's.
I think because Digitranslator thinks your OMF is bound for an Avid it is adding these little clips to ensure that the sound edits lands on a frame line.
This is all part of the "Enforce Avid Compatability" option. If you turn this off, Digitranslator should not pad each edit to the nearest frame boundary.
Old 06-21-2002, 12:16 AM
Thanks for the info. Yes these omfs are headed for an Avid - only re-importing to make sure that they work. So, do you know off hand, if these little files will show up on the Avid side?
Michael Klinger
Tree Falls Post
Los Angeles
(323) 851-0299
mike@tfpost.com
www.tfpost.com
Old 06-21-2002, 01:27 AM
Yes, they will appear in the Avid:
http://duc.digidesign.com/cgi-bin/ub...c;f=6;t=000590
Old 06-21-2002, 01:35 AM
Default little problem with Pt to omf export
I am exporting very basic single track narration record sessions pt5.13 as OMF aif. When I check the omf full circle and import back into PT, I have noticed little one frame clips before and after every narration take labeled as "sample accurate edit" . I have no fades on the clips, and I am not using the auto region fade in/out
How can I avaoid these?
Michael Klinger
Tree Falls Post
Los Angeles
(323) 851-0299
mike@tfpost.com
www.tfpost.com
HTML code is On
export problem GStyle Pro Tools M-Powered (Win) 2 04-24-2006 08:10 PM
MP3 export problem K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-15-2005 01:45 AM
MP3 export problem ...please help Lanois WannaB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-05-2005 09:43 AM
problem with mp3 export and btd - help bigdude Pro Tools TDM Systems (Win) 2 01-04-2004 02:43 PM
5.1 MP3 export problem ? Jussi Tegelman Pro Tools TDM Systems (Mac) 0 10-29-2002 09:52 PM
