Protools suddenly running uber slow...
Hello!
All of my Protools sessions suddenly started running extreamly slowly. The sessions will play when I first open them for about 3 seconds. I will get an error that tells me to adjust my playback engine. I have tried every playback engine setting to no avail. After that initial error, PT will become so sluggish that I cant play the session or get any work done. This is happening regardless of how many plug ins the session has. I run a registry cleaner often. The sessions are on an internal HD (7200) that is 90% full. What could be causing this problem? It is very frustrating and I cant release the beautiful music I am making! |
Re: Protools suddenly running uber slow...
Lincoln Mitchell www.studiofifty.net Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue |
SiSoftware Sandra
Computer Model : Asus G73Jh Workgroup : WORKGROUP Host Name : ChasePC User : Chase Processor Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz Speed : 1.85GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Asus G73Jh BIOS : AMI G73Jh.206 02/26/2010 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DDR3 SO-DIMM Chipset Model : ASUS Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.56GHz (5.11GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.27GHz (4.54GHz) Total Memory : 8GB DDR3 SO-DIMM Memory Bus Speed : 2x 710MHz (1.42GHz) Memory Module(s) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Mobility Radeon HD 5870 (800 SM5.0 700MHz, 1GB DDR5 2x1GHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Mobility Radeon HD 5870 (800SP 10C 700MHz, 1GB 2x1GHz) Adapter : ATI Mobility Radeon HD 5870 (800SP 700MHz, 1012.2MB 2x1GHz) Storage Devices Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:) Seagate ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ) : 932GB (H:) TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (E:) Logical Storage Devices OS (C:) : 116GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) DATA (D:) : 330GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) KACZ BACKUP (H:) : 931GB (NTFS) @ Seagate ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ) Pro Tools LE (E:) : 8GB (CDFS) @ TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ASUS EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) AA01h Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20) Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Are you using a USB drive for audio? If so is that or anything else new?
Nope, my audio is on an internal SATA drive.
Nothing else is new. This kinda stuff makes me wanna get a Mac. |
I use a Mac but plenty of people have incredible pc's. Have you followed all of the recommended optimizations?
Also if your audio drive is that full, could you try off loading some to another drive? What version of pro tools and what interface?
Are you recording to a partition of the system drive, or a separate physical drive(you need a separate hard drive for recording)? Wireless and bluetooth should be disabled when running Pro Tools. I would move some older sessions off to another drive to see if it helps(I hate having a drive 90% full). You also probably should not be fussing with the registry very often.
Cleaning the registry should only be done after a reliable clone is made. Use Acronis True Image. This will also prevent wondering what the issue is when things go bad. Just pop in the clone and all is well.
As Albee said the 90% full session drive is not the best, I would offload at least another 10% if this is a separate physical drive. Your C: and D: drive appear to be partitions of the same physical drive. Be sure you are not trying to use that drive for sessions. A partitioned system drive is about the worst of all choices for sessions. He is also spot-on about the Wireless and Bluetooth...Shut 'em down.
If you are, as you say, recordin to your internal laptop c drive and its 90% full that is most likely the reason. Your system needs that drive to have some free sapce and Protools only supports recording to a seperate drive. Now that its that full its probably fragmented too slowing it down to a crawl.
So first thing to do is get those sessions out to an external HDD I dont recomend cleaning the registry either.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
Thanks for the prompt advice guys!
I meant to say that my drive is 90% EMPTY not 90% full hahaha my bad! It is a separate internal hard drive, not a partition of another one. I had no idea I wasnt supposed to clean my registry! What effect does this have on protools? I cleaned my registry a few times in the last week and that would definently explain this problem! How can I reverse the effects of cleaning it? I don't have a backup of how my computer was before. Thanks again! |
ProTools SE running slow/glitchy?? | defamationx99 | Pro Tools SE and Essential (Mac) | 3 | 09-05-2012 03:47 AM |
Macbook running very slow with ProTools | story3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-12-2009 08:25 AM |
ProTools running slow | Paul Seed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-29-2008 06:48 AM |
session suddenly running extremely slow | jonahjonahjonah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-16-2006 07:32 PM |
PROBLEM - PROTOOLS LE SESSIONS SUDDENLY SLOW | nickster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-13-2004 02:23 AM |
