HD Analog I/0 16 built in optical ports
I just got a HD Native card and an I/O Analog 16.
I was under the impression that the additional built in optical ports and spdif are actually additional to the 16 analog ports... In other words I was hoping to use the 16 i/o's for summing and then go out optical (adat) to my apollo twin for monitoring... now it seems that the total is 16 channels so I can replace for example 15/16 with 1/2 optical, which means I am 2 channels short for what I had planned... Is that correct or is there a way to actually use the 16 analog outs + the additional adat ports 1 to 8? Please let me know Thanks
PT Ultimate 2021.10 Nuendo 10.3 Wavelab Pro 11 UAD Satellite Octo Thunderbolt, UAD Quad Pcie Apollo Twin Duo, HDX Card, 2x Avid I/O Analog 16/16, 4x Artist Mix, Avid Dock, PT Control, 2019 Mac Pro 12 core, 48 gig Ram, running Big Sur, lots of outboard gear |
The HD I/O box is 16 paths, in your case that is 16 analog in and out
Now you can mult output paths so say analog 1/2 is also the AES/SPDIF on the chassis or you can put the optical ports into ADAT mode for more digital paths You can sub an analog pair for a digital pair of the inputs if you need to
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
thanks
argh not the answer I was hoping for but I'll make it work
If you have some rack space, a used 192 IO will expand your setup nicely for a relative bargain
that won't work with PT12 though won't it?
wow, didn't know that... that seems like a good compromise option
thanks!
Actually a "great" option. Before you buy, be aware of the different versions of 192 that are on the market. The 192 digital is strictly digital(meaning you need analog>digital hardware to use it). The "standard" 192 is 8 analog IO and 8 digital IO(with an expansion slot to add 8 more analog ins, or outs, but not both). And a warning to be careful as there are people selling 192 chassis with no cards(they don't work at all without at least 1 digital card) so you don't buy one of those, thinking its all you need. That's my understanding anyway
AFAIK, there must be 2 working cards in slots 1-3 and slot 4 is totally optional. If you have analog in and out in slots 1-2 without digital card, it should work standalone, but cannot sync to other boxes.
Bus audio from Macbook built-in optical out to 002R using ADAT | Megageoff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-27-2011 06:22 AM |
MacBook Pro built-in ports/external startup drive question | Sequence8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-06-2007 04:31 PM |
Using built-in optical audio inputs | DaveSullivan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-23-2006 10:34 AM |
For any OO1 user using both optical ports (i/o) | kindkind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2006 02:52 AM |
Is there an Analog adapter for the Optical ports? | Moot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-06-2000 05:25 PM |
