Moving your home folder to another drive
Dear Mac Sages
If I were to boldly move (whoops - a split infinitive) my home folder to another drive, does this affect my Pro Tools HD? cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Wow - no one know the answer to this?
Re: Moving your home folder to another drive
you might run into problems just moving it. what is it you're trying to accomplish exactly?
are you trying to make a copy of it onto another drive or do you actually want to move where the folder actually exists. i think you should try and make a clone of your system hard drive. i used "carbon copy" (recommended by someone here) to make a clone of my system. |
I have Super Duper and will of course clone. I am happy moving my home folder, I am just not sure of the implications re PT. AFAIK PT just has to have an admin account to work - does it care where your home folder is?
cheers
By home folder do you mean your user folder? Why would you want to move it anyways?
I have multiple partitions, Snow Leopard for PT, Snow Leopard for Media Composer, Leopard for PT (various versions). I wish to be able to access my home folder easily from all.
cheers
Careful with the 'Library' folder - I know your a post-guy and for example, I know Soundminer keeps all its databases and prefs there for a start (and I think I've seen Propellerhead Reason files in there too). Would it be worth just moving your itunes/movies/documents folders elsewhere and leave the more 'system' based ones as is? Not exactly what your after but you could have major instability issues cropping up otherwise.
Try System Preferences/Accounts & control click your user a/c - theres an option to set the path for your user folder under advanced settings. Wouldn't advise it without full cloned BU's of everything of course! |
mm - do have soundminer
may need more research on this
AFAIK each of your partitions would have it's own set of users folders.
Moving RTAS plugins folder - ProTools 10 | thghgv | Windows | 5 | 05-27-2013 07:46 PM |
SSD for System Drive, relocating home folder? | RSSstudio | macOS | 4 | 01-24-2011 05:07 PM |
Structure-moving sample library to new drive and/or folder | Red58 | Virtual Instruments | 5 | 06-20-2010 02:24 AM |
Strike Keeps moving to Unused Plugins Folder | Keefriffhard | Virtual Instruments | 4 | 04-08-2009 04:50 PM |
Protools files in Home folder | timburby | Pro Tools TDM Systems (Mac) | 1 | 05-16-2008 05:09 PM |
