Unable to Locate Digidesign Hardware
I have a problem with using Pro Tools LE 7.3. I have an Mbox 2. Whenever I try to start the program it gives me a dialog saying, "Unable to Locate Digidesign Hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready.
On the Mbox2, the USB green LE is on, Input 1 Mic green LED on, and Input 2 Mic green LED on. System Specs: Asus P5QC Motherboard Intel Core 2 Quad Q8200 Nvidia Geforce 8600 GT OC Windows XP SP3 Mbox 2 Pro Tools LE 7.3 2x2GB Corsair XMS2 (PC-6400) 500 GB Seagate Barricuda(Internal) I have re-installed the software numerous times and with/without plugins. I have 2 Mbox2 and both give me the same error, tested them both out. Tried new firewire cables. Tried different USB ports Installed Quicktime. Tried updating but it installer said I do not have it installed or the program is corrupted and opted me to re-install which I did. Sandra Report: ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Server Status >>> -------------------------------------------------------------------------------- Name: SiSoftware Sandra Lite [Evaluation] (x86) Version: 2009.1.15.72 Copyright: Copyright © SiSoftware Ltd 1995-2009. All Rights Reserved. Registered Owner: Joey Licence Status: Evaluation copy, strictly for personal/ educational use only. For business/commercial use, it can be trialled for 21 days. Licence Extra: You are on day %i of your evaluation period. Please see the SiSoftware site (http:// www.sisoftware.co.uk) for purchase details. URL: http://www.sisoftware.net/sandra/ E-Mail: [email protected] User: Joey Host Name: JOEY-1D6GH1TZOD System ID: {40950AB2-5E53-4EA1-B111-936E1F72A512} Run ID: {0A777E41-3581-4A18-BE72-686475B2E8C6} Date: Saturday, January 03, 2009 @ 2:20:56 PM <<< Report Comments >>> -------------------------------------------------------------------------------- Comments on report: Full System Specs. <<< Computer Overview >>> -------------------------------------------------------------------------------- < System > Host Name: JOEY-1D6GH1TZOD User: Joey Workgroup: WORKGROUP < Processor > Model: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed: 3.29GHz Cores per Processor: 4 Unit(s) Threads per Core: 1 Unit(s) Type: Quad-Core Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < System > System: System manufacturer P5QC Mainboard: ASUSTeK Computer INC. P5QC Bus(es): ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes System BIOS: American Megatrends Inc. 1103 Total Memory: 3GB DIMM DDR3 < Chipset > Model: ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed: 4x 470MHz (1.88GHz) Total Memory: 4GB DIMM DDR3 < Memory Module(s) > Memory Module: Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2- 6400U DDR2-800 (5.0-5-5-18 3-22-6-3) Memory Module: Corsair CM2X2048-6400C5 2GB DIMM DDR2 PC2- 6400U DDR2-800 (5.0-5-5-18 3-22-6-3) < Video System > Adapter: NVIDIA GeForce 8600 GT (512MB DDR3, 525MHz/ 1.22GHz/2x702MHz, PCIe 1.00 x16, PS3.0, VS3.0) < Graphics Processor > Adapter: GeForce 8600 GT (1.01, 512MB, 1.24GHz) < Storage Devices > ST3500320AS 500GB (SATA150, 3.:466GB (C:) (D:) TSSTcorp CDDVDW SH-S203N (SATA:N/A (I:) < Logical Storage Devices > Hard Disk (C:): 244GB (NTFS) @ ST3500320AS 500GB (SATA150, 3.5", NCQ) Hard Disk (D:): 222GB (NTFS) @ ST3500320AS 500GB (SATA150, 3.5", NCQ) CD-ROM/DVD (I:): N/A @ TSSTcorp CDDVDW SH-S203N (SATA150, DVD+- RW, CD-RW, 2MB Cache) < Peripherals > LPC Hub Controller 1: ASUS LPC Interface Controller Audio Device: ASUS HD Audio Controller Audio Codec: Realtek Semiconductor 888 High Definition Audio Serial Port(s): 1 Disk Controller: ASUS 4 port SATA IDE Controller Disk Controller: ASUS 2 port SATA IDE Controller USB Controller 1: ASUS USB UHCI Controller #4 USB Controller 2: ASUS USB UHCI Controller #5 USB Controller 3: ASUS USB UHCI Controller #6 USB Controller 4: ASUS USB EHCI Controller #2 USB Controller 5: ASUS USB UHCI Controller #1 USB Controller 6: ASUS USB UHCI Controller #2 USB Controller 7: ASUS USB UHCI Controller #3 USB Controller 8: ASUS USB EHCI Controller #1 FireWire/1394 Controller 1: ASUS FW322/323 IEEE1394 OHCI FireWire Controller System SMBus Controller 1: Intel 801xx/63xx SMBus < Printers and Faxes > Printer: Microsoft XPS Document Writer (600x600, Colour) Printer: Brother PCL5e Driver (600x600, USB) < Network Services > Network Adapter: Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance: x86 <<< Processor Arithmetic >>> -------------------------------------------------------------------------------- < Benchmark Results > Dhrystone ALU: 51.47GIPS Whetstone iSSE3: 46.99GFLOPS Results Interpretation: Higher index values are better. < Performance vs. Speed > Dhrystone ALU: 15.64MIPS/MHz Whetstone iSSE3: 14.28MFLOPS/MHz Results Interpretation: Higher index values are better. < Performance Test Status > Run ID: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4C, 3.29GHz, 41% OC, 2x 2MB L2, 1.88GHz FSB, 41% OC) Platform Compliance: x86 NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 4 Multi-Core Test: Yes Cores per Processor: 4 SMT (Multi-Threaded) Benchmark:No Processor Affinity: P0C0T0 P0C1T0 P0C2T0 P0C3T0 System Timer: 3.29GHz Number of Runs: 64000 / 640 < Processor > Model: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed: 3.29GHz Cores per Processor: 4 Unit(s) Type: Quad-Core Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < Features > SSE Technology: Yes SSE2 Technology: Yes SSE3 Technology: Yes Supplemental SSE3 Technology: Yes SSE4.1 Technology: Yes SSE4.2 Technology: No AVX - Advanced Vector eXtensio:No FMA - Fused Multiply Add eXten:No SSE4A Technology: No SSE5 Technology: No HTT - Hyper-Threading Technolo:No < Performance Tips > Notice 5008: To change benchmarks, click Options. Notice 5004: Synthetic benchmark. May not tally with 'real- life' performance. Notice 5006: Only compare the results with ones obtained using the same version! Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. <<< Processor Multi-Media >>> -------------------------------------------------------------------------------- < Benchmark Results > Multi-Media Int x8 iSSE4.1: 122.13MPixel/s Multi-Media Float x4 iSSE2: 68.13MPixel/s Multi-Media Double x2 iSSE2: 34.50MPixel/s Results Interpretation: Higher index values are better. < Performance vs. Speed > Multi-Media Int x8 iSSE4.1: 37.12kPixels/s/MHz Multi-Media Float x4 iSSE2: 20.71kPixels/s/MHz Multi-Media Double x2 iSSE2: 10.49kPixels/s/MHz Results Interpretation: Higher index values are better. < Performance Test Status > Run ID: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4C, 3.29GHz, 41% OC, 2x 2MB L2, 1.88GHz FSB, 41% OC) Platform Compliance: x86 NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 4 Multi-Core Test: Yes Cores per Processor: 4 SMT (Multi-Threaded) Benchmark:No Processor Affinity: P0C0T0 P0C1T0 P0C2T0 P0C3T0 System Timer: 3.29GHz Rendered Image Size: 1920x1080 < Processor > Model: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed: 3.29GHz Cores per Processor: 4 Unit(s) Type: Quad-Core Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < Features > SSE Technology: Yes SSE2 Technology: Yes SSE3 Technology: Yes Supplemental SSE3 Technology: Yes SSE4.1 Technology: Yes SSE4.2 Technology: No AVX - Advanced Vector eXtensio:No FMA - Fused Multiply Add eXten:No SSE4A Technology: No SSE5 Technology: No HTT - Hyper-Threading Technolo:No < Performance Tips > Notice 5008: To change benchmarks, click Options. Notice 5004: Synthetic benchmark. May not tally with 'real- life' performance. Notice 5006: Only compare the results with ones obtained using the same version! Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. <<< Multi-Core Efficiency >>> -------------------------------------------------------------------------------- < Benchmark Results > Inter-Core Bandwidth: 13.42GB/s Results Interpretation: Higher index values are better. Inter-Core Latency: 40ns Results Interpretation: Lower index values are better. < Performance vs. Speed > Inter-Core Bandwidth: 4.18MB/s/MHz Results Interpretation: Higher index values are better. Inter-Core Latency: 0.01ns/MHz Results Interpretation: Lower index values are better. < Detailed Benchmark Results > Processor Affinity: CPU0-CPU1 CPU2-CPU3 2x8kB Blocks Bandwidth: 10.58GB/s 4x8kB Blocks Bandwidth: 11.44GB/s 2x32kB Blocks Bandwidth: 14.37GB/s 4x32kB Blocks Bandwidth: 28.26GB/s 16x8kB Blocks Bandwidth: 26.63GB/s 2x128kB Blocks Bandwidth: 29.04GB/s 4x128kB Blocks Bandwidth: 29.11GB/s 16x32kB Blocks Bandwidth: 28.50GB/s 64x8kB Blocks Bandwidth: 26.75GB/s 16x128kB Blocks Bandwidth: 3.92GB/s 64x32kB Blocks Bandwidth: 4.10GB/s 64x128kB Blocks Bandwidth: 2.51GB/s < Performance Test Status > Run ID: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4C, 3.29GHz, 41% OC, 2x 2MB L2, 1.88GHz FSB, 41% OC) Platform Compliance: x86 Buffering Used: No NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 4 Multi-Core Test: Yes Cores per Processor: 4 System Timer: 3.29GHz Page Size: 4kB Use Large Memory Pages: No < Processor > Model: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed: 3.29GHz Cores per Processor: 4 Unit(s) Type: Quad-Core Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < Performance Tips > Notice 5008: To change benchmarks, click Options. Notice 5004: Synthetic benchmark. May not tally with 'real- life' performance. Notice 5006: Only compare the results with ones obtained using the same version! Tip 11: Use the 'Switch Chart Type' button to switch between Detailed and Combined charts. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. -------------------------------------------------------------------------------- << ALU Power Performance >> << 50i/25Hz (25fps, e.g. interlaced PAL video) >> |
Re: Unable to Locate Digidesign Hardware
You say its an Mbox 2 but you tried different firewire cables?? Is it the USB Mbox 2, or the firewire Mbox 2 PRO? Assuming its the USB box, the best USB port to use are the ones near the keyboard and mouse ports on the back as they are mounted directly to the motherboard. I would uninstall using the ptnuke utility and start over and always use the same port(good advice with ALL USB devices anyway).
I am using the USB Mbox 2, I just meant by using same cables but just testing out other's of the same to see if that cable could be bad. I have it plugged in to the back of my computer to on of the ports. Where can I get the ptnuke utility?
bump
try uninstalling and reinstalling Pro Tools. Just pay close attention and ignore the found new hardware from windows.
When it says, Installing Drivers, some dialog windows pop-up saying that the driver is not windows signed and asks me to continue installation or stop. If I do not click it anything, the installation process does not continue.
That's normal for it to give the 'not signed" message. Continue anyway.
Ok, well I did click continue and it installed all the drivers. Pro Tools still giving me the unable to locate digidesign hardware window.
I forgot to mention that I am running a dual OS boot, Vista x64 and XP pro x32.
Is the mbox2 appearing under USB devices in the device manager?
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on. | qillster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-09-2011 06:49 PM |
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on.. | qillster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2011 09:08 PM |
Unable to locate digidesign hardware. Make sure your hardware is connected ... | muso90 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-14-2010 01:57 AM |
Unable to Locate Digidesign hardware. | Tbob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-04-2010 10:14 AM |
Unable to locate Digidesign Hardware | cultureofgreed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-26-2005 09:31 AM |
