\"Slipping\" Audio Within a Region
Rumor has it that there is a key command for nudging audio forward and backward within the region, ie the waveform moves but the region stays in place. Of course, this is dependent on if you have sufficient handles in the file outside your region.
Some nonlinear editors have what's known as a "slip" tool that performs this. Anyway, can't find any hint to it in the docs. Anyone?
G5 Quad, 12gig, OSX.4.9, 002r, RME Digiface&Multiface, UAD-1x4, Magma chassis, Unitor8+AMT8, Capybara 320 |
Re: \"Slipping\" Audio Within a Region
I may be wrong about this, but by definition, any fraction of a piece of audio becomes a separate region, so you can't move audio within a region, because by definition, it becomes another region..... Did you have some other meaning in mind?
Control + or - on the keypad should do the trick. Highlight the region first. - moves the audio later, + moves it earlier. This is the opposite of the nudge keys. Old habits, I guess.
Bob
Save early and often! (or once a day whether you need to or not...) |
Isn't that the command for trim right edge of region.
I believe he's asking how to move the audio within the current region bounds. |
Thanks alot! PS, it'd be nice if there was a modifier for the grabber tool to do this, but the key commands are excellent for fine tuning.
Bob
Nudging a Region’s Contents
Often a region’s start point will reside at the correct location, perhaps at a SMPTE frame or bar, but the material within the region starts too late or early. You can, in effect, nudge a region’s audio waveform or MIDI notes without displacing the region’s start and end points. This “sliding” of region contents is only possible if there is material residing outside the region’s start and end points—from the region having been trimmed, or perhaps captured from a larger region. 1) Configure the Nudge value. 2) With the Time Grabber tool, select the region whose contents you want to nudge. 3) While pressing the Start key (Windows) or Control (Mac), press Plus (+) or Minus (–) on the numeric keypad to move the material by the Nudge value. Super cool trick! |
OMF WAV Clips Slipping | Nathan W. | Post - Surround - Video | 1 | 05-05-2011 10:50 AM |
OMF Slipping | splicestudios | Post - Surround - Video | 1 | 04-14-2011 10:22 PM |
Pro Tool 6.4 LE Audio Tracks slipping??? | JAG5020 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-30-2009 08:41 PM |
Slipping Audio Within a region | Chuck Harris | General Discussion | 4 | 01-27-2009 12:34 PM |
slipping audio within a region - can't remember the modifier | tonmeistermat | Pro Tools TDM Systems (Mac) | 5 | 11-23-2007 01:48 PM |
