Word Clock Question
Hello Forum I have a opportunity to pick up a Big Ben word clock, I've read that u can connect it to any PTLE hardware via s/pdif but is it still possible to record audio thru the adat lightpipe while using s/pdif for clocking??? or the other way around...can I still use s/pdif for audio while I use lightpipe to except external clocking... Thanks in advance for all help and advice!
Mbox Pro, PT 7.1.3, Music Toolkit, P4 2.8GHz, Cubase SL, Sampletank 2.1, Sonik Synth, Guru, Pod Pro, Final Scratch2, Numark TTX, Vestex 05, MPC500. |
Re: Word Clock Question
Well yes, kinda. You'd also need to send the Big Ben clock to whatever your other digital device is so that everything is clocking from the same source.
Yes I have several devices that has BNC connection, just wanted to make sure the main piece in my studio can accept it and at the same time allow me to use the other digital format as I/O
Well, I would assume that if you set the 002 to "Slave" and linked the Big Ben to the ADAT or SPDIF source, that could do it.
Thanks again Slim Shady, Thats not a piece of equipment you buy in the hopes that it might work...appreciate the help!
I record through the optical in via an ADA8000 so in theory yes you can record Via the Optical In, using the Big Ben I don't know as I haven't tried it.
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
Thanks...this is how it be setup... wordclock into the digi 002r via lightpipe and a computer I use for soft synths going into the digi 002r via s/pdif I'm just making sure I was on the right path.
Word clock question | TornadoTed | Pro Tools TDM Systems (Mac) | 2 | 01-31-2013 07:29 AM |
Word clock cabling question | losttimestudios | Pro Tools TDM Systems (Mac) | 0 | 07-05-2005 09:06 AM |
D/A converters for my 001...WORD CLOCK QUESTION | danocaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-12-2004 09:47 AM |
Word clock question | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-18-2003 01:45 AM |
192 I/O Word Clock Question | rnt_u_listnng | Pro Tools TDM Systems (Mac) | 2 | 06-25-2003 07:05 PM |
