NTFS or FAT32?
I was thinking NTFS for my system drive (When XP driver is here) maybe keeping audio drive as FAT32? Does anyone know if it matters? Should we all stay FAT? or make that change?
Cheers.
http://digi001.epizy.com |
Re: NTFS or FAT32?
You can stay fat 32 on all drives or move to NTFS on your OS DRIVE. Either way your os will run clean, and at any time, if you wish to move to NTFS on the OS drive you can with the click of a mouse. I and I'm sure others would not recommend it for your audio drive.
Re: NTFS or FAT32?
system drive NTFS, audio drives FAT32. it's gonna have to be that way until some minor issues are resolved in the next release.
Re: NTFS or FAT32?
just wondering if it would effect my sessions, say after a clean install of XP, both system and audio drives on NTFS,.. because the audio was saved on FAT32 and opened on NTFS will it be ok?
Not sure how this FAT/NTFS thing works but I'm a little worried. [img]images/icons/frown.gif[/img]
Re: NTFS or FAT32?
damn you got to be quick round here, thanks mattm/Citi,.. I was thinking along those lines.
Re: NTFS or FAT32?
I thought this was funny. I just ordered fatty and greasy chinese. I think my audio drive will be staying fat a wee bit longer... |
Re: NTFS or FAT32?
Trust me. If your computer runs at 1Ghz or faster, NTFS all the way. Its a more efficient filing system. Some say it will slow your drive down. No, it won't. I run a NTFS drive for Nuendo. When I made the switch from Fat 32, I loaded up a song that I was working on that had 68, 24-bit tracks. It ran no different. You just get a few more options like file encryption for security for you projects. If your files are encrypted, they will be protected from viruses that are caused by another persons user profile. The virus will not have access to your session files because a code (that you create) is required to modify your files in any way (deleting, or corruption). For that matter, No one will have access to your files. No accidents! Well unless you make them. [img]images/icons/wink.gif[/img]
Jayman #9 |
Re: NTFS or FAT32?
Calling Mark Knecht, Mark? you around? NTFS or FAT32 what do you think? [img]images/icons/confused.gif[/img]
Take Care, Gabriel. |
Re: NTFS or FAT32?
It's really, really weird when you get to the bottom of a thread and find this!! Weird.
In a perfect world, when PTLE is running you won't be accessing your system drive at all. IF that's the case, then NTSF/FAT won't matter while running. My number one reason to NOT use NTSF (admittedly a bit outdated) on my system drive is that if I boot my machine with a DOS floppy, with FAT I can see my system drive, while with NTSF I can't. I do boot with DOS once in awhile, so to me it's important. More important would be getting a version of Norton Ghost that supports NTSF. I'm sure it's out there, but I'd want to check first. I doubt this really answered your question. Basically, go with which ever makes you happy. They're both good. Cheers, Mark |
Re: NTFS or FAT32?
Or get Drive Image which supports NT/XP! [img]images/icons/wink.gif[/img]
Another thing is if you're going to a Dual Boot, the partition you make NTFS is going to be invisible to the 9x partition/OS; You will not be able to share files between the two OS's. If you make 'em both '32, you would. Something to consider as you choose. As far as I've heard, one of the key things about NTFS is the security angle, but for our purposes that's probably a minor consideration. So- there we have a 360 degree view of the issue! |
Fat32 or NTFS? | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-07-2006 09:54 PM |
NTFS or FAT32??? | silence_of_stone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-19-2003 07:03 PM |
FAT32 vs NTFS | vanb777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-20-2003 07:00 PM |
NTFS or FAT32 | rotsh1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-16-2003 05:51 AM |
NTFS or FAT32 | darkwar3 | Pro Tools TDM Systems (Win) | 2 | 09-26-2002 12:28 AM |
