who\'s using patchbay and mixer?
Simply out of curiosity, that's all.
Some people have just the 001, some have the 001 and an external mixer, while others have both and patchbay on top of that. If you have all three (or more than one of each) in your setup, how do you have it configured for the tracking and mixing purposes? Ever get confused as to what's gone where and fed back into somewhere else? Let us know how it's working out for ya! pk
www.myspace.com/krou |
Re: who\'s using patchbay and mixer?
All the above for me...
32 ch A&H GS3000 mixer w/tube pre's, in & outs to a balanced patch bay, inserts to an unbalanced patch bay... 24 track Reel to Reel Tascam MSR24S W/Dolby S in & outs to a unbalanced patch bay... Digi 001 ins to a balanced patch bay... Alesis AI-3 ins to a balanced patch bay, lightpipe to the 001... It's really easy once it's all set up and stuff is on there own bay... The patch bay lets me record drums on analog then transfer to PTLE very quickly, or record straight to PTLE and use any ch/pre amp on the mixer... [img]images/icons/wink.gif[/img]
recordingguy Recording Guy's Studio & Sound www.recordingguy.com Cedar Rapids, IA |
SL6000E - has left-hand side patch bay. quite a find, i believe. and al smart did up the line amps and installed the '4000 mode' mod.
as good as it sounds, it doesn't go anywhere near as loud or deep as a VR. |
Yep...have and Alesis 32 mixer and patchbays...basically the patchbays are used to route my sound modules, MPC, etc to the channels of my mixer than buss those channels into the digi...patchbays keep me from having to plug and unplug and insert and blah blah...everything in my studio is rackmounted and my patchbays are labeled...
There's a really good piece on building patchbays in the current issue of TapeOp. If you're not a subscriber, I'd highly recommend it- it's about the only magazine that isn't of the same Mix/Electronic Musician/Guitar Player/ EQ etc. slick mold. It's more like real people.
Free subscription online at: http://www.tapeop.com/ Most ADAT converters have outputs, too, so you'd have to do a S/PDIF coax conversion too. That'd be 18. Check out Frontier Design's Tango 24, for example. |
RE: 16 channels to mix yeah you can do it, get an 8 channel D/A converter with optical - run your 8 outs from this to board. Use the other 8 analog outs of the 001 to board. I use the RME ADI-Pro 8, 8 channels A/D and D/A
mixer to the AI-3 to the 001 "via lightpipe", out of the 001's lightpipe to the AI-3 light pipe, then out of the AI-3's 8 analog outputs to the mixer returns/tape in's... [img]images/icons/wink.gif[/img]
XP2500+, a7v8x-x, 60/80G drives, pc2700 Micron, SIIG 3 port, win xp home, Radeon video, ADS/WD 120 FW drive, 002r PTLE 6.1.1 stable as can be. |
I want to mix on the console, at least 16 channels, is there a way to have 16 direct outs, out of the 001?? I know you can have 16 in, with an Adat bridge or something... but I need 8 extra channels out, besides the ones on the 001
"I never hit a women with her clothes on!" |
Delta 1010 Monitor Mixer/Patchbay Router ?? | digginin9 | Pro Tools M-Powered (Win) | 3 | 02-14-2007 05:41 PM |
Digi 001 + Mixer + Patchbay? | dietcookie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-14-2005 04:23 AM |
Which To Use...A Mixer or Patchbay??? | AFX | Tips & Tricks | 6 | 05-02-2004 11:01 AM |
to patchbay or not to patchbay (micpres) | Camilo Orozco | Tips & Tricks | 10 | 12-07-2001 12:51 AM |
mixer setup and midi patchbay | keysmia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-20-2000 09:27 AM |
