5.1.3 on a G4 dual 1.25ghz anybody?
Hi all,
So i "upgraded" to a dual 1.25ghz non FW800 with the intention to be able to use OS9. There are 2 separate HDs /1 is 9.2,the other one 10.3.9/ Here is the problem. When i start up OS9, although the whole desktop is visible, i can't click on any icons. Upon ctrl+alt+command+esc it asks me if i am sure i want to close the ATI accelerator. Well, when i say yes, it makes things function normally, i.e. being able to click on any file on the desktop. Now, here is the actual problem. When i start up Pro Tools, it loads fine up until it ells me to turn on my interface and try again. I power up the 888 before i try to open Pro Tools. It seems like it is not detecting the interface at all and i have never had this problem on a single processor or running 6.4.1 Any ideas, anybody with similar problem? |
Re: 5.1.3 on a G4 dual 1.25ghz anybody?
I have the same G4 and initially had problems with it co-operating with a Digi 001 - the G4 wouldn't even power up with the 001 attached! I think there were issues with PCI voltages or somesuch, after a couple of motherboard replacements I ended up taking the G4 to Apple HQ in West London for them to sort it out! I wonder if your problem is related...?
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
I have it running on the single G4/1.25 with no problem.. Think there was an issue with the second processor. Maybe hide it from OS9..
It's been awhile but wasn't there something in the system folder for that 2nd processor? |
i would, if you haven't already start with a base set of extension and also enable the proper Digidesign ones. I forget what actually is enabled but, it is probably in the support archives here. If everything works in OS X then it is more than likely an extension problem in 9
My old PT 24 Mix Rig is still up and working, this is the configuration:
Mac G4 Dual 1.25 GHz (FW 400) + 2 GB RAM + ATTO UL3D OS X 10.3.9 + PT 6.4.1cs4 + Logic Pro 7.1 or OS 9.2.2 + PT 5.1.3 + Logic Audio 4.8.1 or OS X 10.4.11 + PT LE 7.4cs4 + MBox PT 24 MIX 4 (1 x MIX Core + 3 x MIX Farm) + 4 x SampleCell II TDM inside 13-slot 32 bit Digidesign PCI Exp. Chassis 888/24 I/O + 2 x 888 I/O + 2 x Unitor 8 mkII It works rock solid, both in OS 9 and OSX. It is correct you sometimes need a special extension in OS 9 to disable the second CPU, you can find more info here I would advise to do a clean install of OS 9, because the OS does not start as it should and then do a clean install of PT 5.1.3
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Did you install OS9 from the ORIGINAL install disk for this computer? Apparently the only way to make OS9 work on an mdd is with the original install disk that came with an mdd g4. The retail boxed versions of OS9 will not work. There are various posts about this on the apple discussion forums.
http://discussions.apple.com/categor...categoryID=114 |
Does this mean that you can use one processor when running 5.3.1 & two when running 6.4.1?
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Hey John_Toolbox,
No, I wasn't able to. I got the computer off craigslist. It didn't have the original OS9 reboot discs. I have heard about the disable second processor deal too, i just have no idea how. I did also hear hat i have to upgrade the OS ROM file to 9.5.1 which i already did. At the same time it runs 6.4.1 flawlessly. |
Hey Delta,
Unfortunately the file didn't do the trick. Still the same issues. |
I suppose so, yes, I don't use my PT 24 MIX rig not that often any more. I work mostly on my other rig with PT|HD 7 Accel (here I can say for sure my G4 is using it's 2 processors without a problem with PT|HD 7.4)
G4 dual 1.25Ghz | niros | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-06-2003 07:14 PM |
crashes on dual 1.25ghz!!!! | zax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-02-2003 11:55 AM |
Dual 1.25Ghz and 2GB RAM | Dong Son | Pro Tools TDM Systems (Mac) | 1 | 03-01-2003 08:36 PM |
Dual 1Ghz and 1.25Ghz | Greene | Pro Tools TDM Systems (Mac) | 2 | 12-18-2002 08:21 AM |
002 With dual 1.25gHz When???? | antidivine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-24-2002 06:20 AM |
