Invalid authorization code
My authroization code does not work.
In my package i have three codes. Two are located in the Getting started manual and one on the disc-sleeve. Niether of these 3 codes work. I´ve tried it with capitol letter and with out, spaces and no spaces. What is the problem?? |
Re: Invalid authorization code
You didn't say which version of PT you have nor what you are trying to do but this may help:
The following information is about the Pro Tools LE 7 authorization code, sometimes referred to as the Pro Tools LE serial number, and how you can find your authorization code if you own Pro Tools LE 7. The Pro Tools LE 7.0/7.1.x authorization codes begin with either "DIGI070" or "DIGI071" Pro Tools LE 7.3 requires a new serial number, and the Pro Tools LE 7.3 authorization codes begin with "DIGI073" The authorization code consists of 3 groups of 8 characters, with each group of characters separated by a single space. All authorization codes are case sensitive The first 4 letters are all upper case: DIGI All other letters are lower case All “0” characters are zeros, not letters Your Pro Tools LE 7 authorization code can be found in one of the following locations: Inside the front cover of your Upgrading to Pro Tools 7.0 booklet included with Pro Tools LE 7.0 upgrades purchased from a Digidesign dealer Inside the front cover of your Getting Started Guide (version 7.0) if your Pro Tools LE core hardware system already included Pro Tools LE 7.0 or 7.1* *The Pro Tools LE authorization code included with the Mbox 2 Mini is on the back of the Pro Tools LE installation DVD sleeve under "PT LE CODE FOR MAC OS X / WIN XP". See: http://www.digidesign.com/index.cfm?...4&itemid=24312
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Invalid Authorization Code | cppi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-09-2008 03:05 PM |
PT 7.3 Invalid Authorization Code | Joker4432 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-15-2007 11:18 AM |
Invalid Authorization Code | bassistj2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-11-2006 02:00 PM |
INVALID AUTHORIZATION CODE | BENTLIP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-11-2005 04:51 PM |
INVALID authorization CODE | Bobi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-08-2005 09:19 PM |
