Dock Monitor knob stops working after 2022.4 update
__
I updated Pro Tools to 2022.4 and after that installed latest EUCON 2022.4 and also updated Control app. Pretty much everything is working as expected except the monitor knob. I check the Eucon preferences and there it is assigned to CR Monitor (not the new assignable knob) This knob was always assigned to DADMan monitor to control MTRX Studio CRoom. So after this update, it feels like this knob is dead, even with SHIFT it doesn't control Monitor A. I even tried to control Pro Tools Master fader and assigned it Eucon monitor, also doesn't work. __ |
Re: Dock Monitor knob stops working after 2022.4 update
Found the solution:
I had beautiful custom knob that was replacing original Dock's monitor knob. That is not possible anymore with this version of Eucon!!! |
I'm not understanding you?
The weirdest part of this, is that if I have the Monitoring page up on my Control Surface paired with the Dock, the control room volume and cut is on the 4th knob down on the right side of the dock, corresponding to graphic. And my goofy colored rubber knob WORKS on that location. But not on the Monitor CR location. 2 knobs, right next to each other with the same function. One says yes, the other says no to rubber covered knobs. And just since this new update. GO FIGURE. :/ |
2022.4 - blue outline around fader and pan knob | swethington | Pro Tools | 3 | 04-28-2022 09:42 AM |
Logic and Monitor (Control Room) knob on Dock | Oggy | Avid S1, S3, Dock and Control App | 3 | 11-02-2021 01:18 AM |
Request: Custom Mapping of Control Room/Monitor Knob on Dock | oblogic7 | Avid S1, S3, Dock and Control App | 0 | 06-03-2020 11:01 AM |
New knob responce for the Dock | Maro Records | Avid S1, S3, Dock and Control App | 24 | 03-22-2018 04:31 PM |
MIDI Thru stops working after sequence playback stops | kelcarpenter | MIDI | 20 | 03-16-2016 11:43 AM |
