Old 02-02-2023, 02:45 AM
rudio rudio is offline
Default Workspace search freezes in Ultimate 2022.12
I have 3 machines running here with ultimate. they are connected to a big drive that they share (17TB). it all worked smooth on 2022.10, until i updated 2 of the machines to 2022.12.
If i want to search the shared drive via workspace (on 2022.12), the cpu usage get's up to around 400% and stays there....literally forever (i tried it once just for fun over the weekend).
i already erased all the workspace files and tried to catalogue the whole share from scratch....which didn't work...so i had to pick small bundles of it and catalogue them bit by bit, because every now and then, the machine froze doing it's job. so now the job is done, it still won't work like expected.
search results show up, but i can see in the task manager, that it still performes a search...and even if i cancel this task, the cpu-usage won't drop until i quit pro tools....which also just work's if i force-quit it.
something changed here and I don't know how to tackle it.
Old 05-03-2023, 12:50 AM
chaos audio chaos audio is offline
Default Re: Workspace search freezes in Ultimate 2022.12
I have a similar problem with workspace.
When using the workspace, after entering one or two letters in the search field, Protools freezes and is no longer operable. In the task manager the message appears: Attributes Synchronization, Invalid database Key queried
After restarting the computer and deleting the Workspace Catalog with thePT Prefs app, everything works normally again for a while.
Mac Mini 2018, Sonnet Echo III R, HD Native PCIe, Mac OS Monterey, Protools 2023.3.
The behavior was observed with 2022.12., 2023.3
Avid Case : 04619564
PT Ultimate 2023.6, HD NATIV PCIe,
MacStudio Max, Sonnet EchoIIID, MTRX Studio, 2x192, UAD2 Quad, Sonnet Fusion SSD Raid, Dolby Atmos 7.1.4,
Mac OS 13.1.
Old 05-14-2023, 04:43 AM
JRVprotools JRVprotools is offline
The workspace, in general, needs to be fixed. Constantly fails to find files. I have to constantly delete the Pro Tools public folder Workspace.wksp and all file and rebuild. Updating doesn't work either. Wokspace becomes corrupt for no reason. This has been going on for years....
Old 08-06-2023, 12:42 PM
DJEJPRO DJEJPRO is offline
I've done a fresh install on a new Mini M2 Pro, and can totally vouch for this. PT 2023.6 Ultimate, Ventura 13.5, running native.
The workspace is just broken. It starts to display erratic files when tabbing around in catalogs. Also, I don't even want to get started on how clunky and ultimately useless the "tags" are. It worked perfectly on my windows 10 PC running PT 2021.12 Ultimate.
Thank god I have soundly for my SFX search engine.
2022.4 New Pro Tools Search feature not working simonchase Pro Tools 0 04-26-2022 11:28 AM
Workspace search bug veet Pro Tools 12 1 03-07-2016 12:28 AM
Workspace Search Errors Peter Miller Pro Tools TDM Systems (Mac) 2 09-10-2010 01:50 PM
PT8 Search in Workspace bug matt connolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-03-2009 07:44 PM
Workspace Search crash joeyk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-11-2006 01:05 PM
