Old 12-09-2022, 07:43 AM
audiobob's Avatar
audiobob audiobob is offline
Default Re: EuCon Not Working macOS Monterey
My Artist Mix (latest one) is connected via ethernet switch and was flakey...but what helped was to assign it a static IP in the AM settings and change Use DHCP to NO.
Overall, connecting seems to be more consistent but will still flake at times and need to go to EuControl settings and add it to My Surfaces.
Old 01-16-2023, 07:53 AM
bemelodic bemelodic is offline
Tried that and also no luck. I also tried pro tools / eucontrol with and without rosetta and still have that problem. I also uninstalled all the plugins to see if something was causing this, but no luck. Still just have a 10lb paperweight on my desk.
This is extremely frustrating.
Again, I'm using an artist mix with M1 Max Mac Studio with Monterey OS.
Old 01-17-2023, 01:30 AM
steins steins is offline
Did you migrate from you old computer? If so, have you tried renaming your Mac and reboot as described in this thread?
https://duc.avid.com/showthread.php?...k16FfwHGVmi_Es
Stein Tore Sønsteli
Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock
Old 01-17-2023, 06:00 AM
James Steele's Avatar
James Steele James Steele is offline
Assuming you installed the latest software I mentioned previously and updated the firmware if needed? That's very strange because I'm using a Control and Mix unit connected with Ethernet switch to my M1 Max Mac Studio with Monterrey 12.6.2. My units are actually the older Euphonix branded ones, but are working great.
Old 01-29-2023, 08:14 PM
psycho_monkey psycho_monkey is offline
Everything was working fine until 2 days ago.
Eucontrol shows Artist Mix both in "All Surfaces" and "My Surfaces". In PT I have EUCON enabled in Peripherals.
I don't get any connectivity on the mixer. As though it knows it exists but can't communicate. So the screens are blank with exception of the pan bar. Faders down all the way.
I've tried rebooting, uninstalling EUCON, reinstalling it. EUCON is listed in the accessibility under the OS security settings.
Computer and Artist mix are connected to switch via Cat5e.
Hardware:
2022 Mac Studio M1 Max; 32 GB.
Avid Artist Mix
Netgear 5-port un-managed switch
AT&T Fiber Router
Operating System:
macOS Monterey 12.6.1
Pro Tools 2022.10
Did you find a solution here?
I've pretty much got the same setup, slightly different mac and 2 more surfaces, latest PT and Eucon.
Like you - the surfaces are detected and connect, but don't appear in PT even though PT acknowledges Eucon is running.
  #16
Old 01-31-2023, 08:55 AM
kaonashi kaonashi is offline
I've seen Eucon successfully working on M1 Macs running Monterey 12.6.2, further about security changing these settings might help;
Check security and privacy in accessibility in your mac system settings, and make sure you have Eucon and ProTools ticked.
The next thing to try is to reduce your system security settings, here's a link from the apple site > LINK
I'd go for; Reduced security and Allow user management of kernel extensions from identified developers
The new macs are shipped out by default with the highest level of security which could potentially stopping EuCon from working I'm not 100% but worth a go, you can always switch the setting back on if it doesn't fix it. Good Luck!
  #17
Old 01-31-2023, 10:53 AM
Eric Lambert's Avatar
EuCon is still functioning here w/ OS 12.6.2, though it does continue to lose my iPad Control app regularly (the app just closes on its own, so more likely a Control app issue than EuCon itself).
  #18
Old 01-31-2023, 03:10 PM
685 685 is offline
The app on my iPad just updated this morning to 2022.12.140
System info
https://duc.avid.com/member.php?u=57185
"please stop OVER-complicating simple things"
  #19
Old 02-01-2023, 03:43 AM
No solution as of now. I'm quite upset about this.
  #20
Old 02-01-2023, 06:17 AM
I had already tried this... withhout luck.
Mbox not supported by MacBook pro MacOS Monterey 12.x Maripersen Pro Tools 12 4 09-17-2022 09:24 AM
Avid Quartet and macOS Monterey gng75 Pro Tools | Duet & Pro Tools | Quartet 0 04-24-2022 05:41 PM
macOS Monterey 12.3 officially supported! DerrickC Pro Tools 62 04-01-2022 01:31 AM
Mbox3 pro MacOs Monterey SIP suggested Madsvigeholm macOS 5 12-28-2021 09:25 AM
